My twin brother and I happen to have a bit of a nasty driveway, 450 ft but it's up a 40ft hill while simultaneously turning.  We live in the snowbelt off of Lake Erie so we need a serious snow blowing setup.
So the master plan, mount a 54" wide snow blower on the front of a Kei truck.  The two most important parts of the plan are now in motion.  We acquired a snow blower for a zero turn mower of all things.  The plan is to mount two 10hp DC electric motors by V belt to the blower drive and build a big lithium battery pack to run it all.20260201_184737402.JPG.161a548dbec5a7d39bede13ad20e5e2b.JPG20260201_184741040.JPG.79ffa839c68ece933b767f14f72eab23.JPG
The second important part is halfway home, we are right now driving this great little 1999 Suzuki Carry from just north west of Washington DC back to Erie, PA on only the back roads.  It has a 49hp fuel injected engine, 5 speed manual, low range transfer case and an electronic rear diff lock.
20260307_141347934.JPG.da7074ae7c9fc980ae696b265a2c3c0b.JPG20260307_141359362.JPG.dd41653da0be6d0e2b5f961779da2f62.JPG20260307_155011023.JPG.602ee50b3b5bba2464084bc364f1406b.JPG
Sounds like you got a great platform! That's gonna take a lot of juice for that blower to be electric. Is the battery bank going in the bed, or is there space underneath? Good luck on the rest of the trip! That's a lot of ups and downs for that little motor.
Looking forward to the engineering you guys put into this. That Suzuki truck is gonna be the star of the show!
Battery powered snow shooter seems legit as well.
Gonna be a great project to see unravel.
I assure, there is going to be a lot of battery involved, all placed in the bed.  We also plan to use the batteries for back up home power using a 48 volt inverter.
The rest of the trip went well, it was a tremendous number of ups and downs.  Ended up using the truck to transport a different snow blower for a friend the last 90 miles home.
Yep, some engineering will be involved.  The current plan is to put a ball hitch on the back then run a frame underneath to connect to that ball hitch for the majority of the load.  There will be a winch bumper up front with a harbor freight winch to lift up and down.   A couple extra bars and a fair bit of electronics.
Interesting idea.  I suspect you'll struggle to keep the belts alive with the amount of snow you get and the torque of the motors.  All the tractor mount snowblowers are either direct PTO drive using a gearbox, PTO and chain drive, or direct hydraulic drive, and they're much more reliable than anything belt driven and can chew the heavy/wet stuff.
Having battery backup for the house would be a big bonus.  I debated getting a cheap Tesla (or maybe a Ioniq) partly for that.  I have a 6kw Kubota light plant but it's not the ideal thing to run all the time, but it would charge a car fairly efficiently if needed.  Otherwise let the car battery run everything.
We'll see, maybe we end up switching to a chain drive.  This snowblower is originally designed for a Zero turn mower so the input is around 3000 rpm and is driven off of a 5L belt.  We plan a 5L belt on each motor all on roughly 6" diameter pulleys, so there will be a double pulley on the input to the blower with each belt going to the separate motors.  Tractors run 540rpm input so way more torque is needed.
We already have a generator sub panel setup in our house for important loads, well, refrigerator, septic, fireplace blower, a few lights.  It will be nice to not have to buy a stand alone gas generator.
I think the belts should do alright. My Bolens runs either a 36” snowblower or a 32” tiller in heavy clay off of a belt driven PTO. I don’t know how many rpms it’s turning, but as far as I know, the belts are original and I’ve never had one slip.
I just ordered some rear trailer hitch parts for attaching it at the rear.
The blower is the perfect size.  Will have to add some corner markers as you can't see the blower when sitting in the truck.
Built a rear trailer hitch setup for the snow blower build.  The hitch assembly is a 16k lb hitch designed for an RV. 20260426_135023673.JPG.8848597b177125a15707cb87484b708d.JPG
 The brackets that attach to the frame are from an online source called "Lucky's Fab Shop." They make all sorts of bumpers for Kei trucks and offer the bracks to fabricate your own bumper.  we did cut about 1.25" off of the helper leaf springs to allow the hitch to be tucked farther under the truck.
The goal was to get it as close to flush with the back of the truck as possible so as to not add much length to the truck and reduce the moment put on the frame when tongue weight pushes down on it.  20260426_135538162.JPG.2279a5e2d3d554e900ee13a6da3b82ca.JPG
Trailer hitch worked well at hauling around a fairly heavy enclosed trailer, not on the road of course.
  • 2 months later...
On 8/2/2026 at 7:44 PM, DirtyComanche said:
What is the tow rating for that thing?  Or is there one?
There is no tow rating that I'm aware of.
It would not be legal for me to tow anything with it on the road in PA on the antique plate anyway.  I've towed several things with it on private property and it works great at low speeds.  First gear is a granny gear so it's super easy to maneuver around.
Making some more progress on the power side of the snow blower.
We have put together 32kWh of grid storage LiFe cells.  There are four identical packs running 16 series and 2 parallel on the cells.
We procured an EG4 12000XP off grid inverter to charge the batteries and act as a home backup power supply running off of these batteries.20260813_211208569.JPG.9d007c929efa73aefa335d1b4009cd2d.JPG20260813_211225115.JPG.341637d02c16900f6cad55ccb312f9b0.JPG
There will be two identical 20hp brushed DC 48 volt motors driving the blower via V-belts.20260813_211642031.JPG.56b70be41566917e59c9580ac1ab8594.JPG
  • 2 months later...
Working on mounting up the DC drive motors.  20261019_203401140.JPG.2137fd336e41b05fb4b3e7395b6eab52.JPG20261019_203409038.JPG.c968bb66a5ddd0eedf7fc6287b4e1882.JPG
Also have all of the batteries built up and have them running a portion of the house off grid with the inverter that will also be used to charge the batteries when they are used for the blower.20261019_203614561.JPG.16a5cc4b7118ff316eb42ea9df95c036.JPG
