JimiGibbs Posted February 24 Share Posted February 24 My '89 Pioneer did not come with floorboard lights.... I have the plug pictured but I am not getting any power to it. The dome fuse and dome lights are good. Is there another connection I need to check? Something that needs to be changed since it was an option? Also are there 1 or 2 plugs? I can only find one..... Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted February 24 Share Posted February 24 That looks like the correct style of plug but it should not be above the transmission tunnel. The footwell lights are on the outside of each footwell (nearest each door). They bolt to the lower dash trim price. Near the far edges. Edit: if my memory is correct one wire will be pink the other black. Also the plugs did change between years but I forget what year was the changeover. Link to comment Share on other sites More sharing options...
fiatslug87 Posted February 24 Share Posted February 24 Change over was 1990 and Eagle_4SX is correct should be pink and black wires. Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 24 Share Posted February 24 That plug given its in the middle makes me think ashtray light. Turn the headlamps on and test for power. If you have power, then it’s the ashtray lamp like I think it is. Link to comment Share on other sites More sharing options...
JimiGibbs Posted February 24 Author Share Posted February 24 THANKS..... Yep it's the ash tray light. Works with headlights turned on. Plus now I know where to look for the floor board plug. Link to comment Share on other sites More sharing options...
JimiGibbs Posted February 25 Author Share Posted February 25 Got my OEM floor lights plugged in and working..... NOW.... where do they attach under the dash? Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 25 Share Posted February 25 Just now, JimiGibbs said: Got my OEM floor lights plugged in and working..... NOW.... where do they attach under the dash? I wish I had a pic but they attach at the corners of the lower panel. There should be a small tab sticking up in the metal support of the lower dash that lines up with the fork of the bracket itself and should line up with a hole for the screw to go into. The one on the drivers side is hidden by the e-brake release handle. Link to comment Share on other sites More sharing options...
fiatslug87 Posted February 25 Share Posted February 25 Look at the picture in the post I attached above. Link to comment Share on other sites More sharing options...
JimiGibbs Posted February 25 Author Share Posted February 25 2 hours ago, fiatslug87 said: Look at the picture in the post I attached above. Got it..... THANKS!!! Link to comment Share on other sites More sharing options...
