hgeranium Posted November 6, 2025 Share Posted November 6, 2025 What are y’all’s preferred ways of cleaning the engine bay without it being completely meticulous and slow? I find that there’s too many old and brittle wires and lines to think about using a hose or pressure washer. Everything just looks either dusty, dirty, oily, or all of the above. The right side of the engine bay (dizzy side) seems especially problematic with the gigantic mess of wires and lines. Link to comment Share on other sites More sharing options...
watchamakalit Posted November 6, 2025 Share Posted November 6, 2025 My solution to a grease covered engine bay is a couple cans of degreaser from the local parts house and a pressure washer. Works well for me. If there isn't a bunch of oil (yeah right it's a jeep). Then a regular soap and water wash will do. Use caution when rinsing. Some things under the hood don't like to get too wet. Link to comment Share on other sites More sharing options...
89 MJ Posted November 6, 2025 Share Posted November 6, 2025 Oil Eatr degreaser and a pressure washer. Just try to generally avoid the relay center and such. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted November 7, 2025 Share Posted November 7, 2025 Same, use a good chemical to loosen up the grease so you’re not relying so much on the water pressure to remove it. That way you can “rinse” the engine bay. Just try to stay away from seals and wiring along with firewall ports Link to comment Share on other sites More sharing options...
hgeranium Posted November 7, 2025 Author Share Posted November 7, 2025 5 hours ago, ghetdjc320 said: Same, use a good chemical to loosen up the grease so you’re not relying so much on the water pressure to remove it. That way you can “rinse” the engine bay. Just try to stay away from seals and wiring along with firewall ports I know everyone has their own secret sauce but what do you use as degreaser? When I was an auto detailer, I used zep’s stuff but I’m always curious to try new stuff. Link to comment Share on other sites More sharing options...
pizzaman09 Posted November 8, 2025 Share Posted November 8, 2025 For areas that are more muddy/dusty, my preferred chemical is Whitewall Tire Cleaner. Then I just use a damp rag and a drum of elbow grease. It's meticulous and slow but works well without destroying anything. Link to comment Share on other sites More sharing options...
hgeranium Posted November 8, 2025 Author Share Posted November 8, 2025 2 hours ago, pizzaman09 said: For areas that are more muddy/dusty, my preferred chemical is Whitewall Tire Cleaner. Then I just use a damp rag and a drum of elbow grease. It's meticulous and slow but works well without destroying anything. Yep knowing my luck, the second I put a pressure washer to the engine bay, there goes all my vac lines. One of these days I’ll have to spend a morning getting everything by hand sometime Link to comment Share on other sites More sharing options...
