1JTHS6413HT058633
NickyV
Year: 1987
Make/Model/Bed: Comanche/Base/Short Bed
Engine: 2.5L
Transmission: AX4 (It's definitely a four-speed manual!)
Transfer Case: It is 2WD, so no transfer case, right?
Front Axle/Rear Axle/Wheelbase: I don't know about the axles, but I think they are from factory. Wheelbase is 113 inches, I believe.
Build Date: Sticker on the door is not clear.
Current Location: Bay Area, California
Status: Roadworthy. Not a daily driver, but I drive it regularly around town and take it on camping trips.
BODY: TL61
BUILD: 11/12/86
SELLING DEALER: TIFFIN MOTORHOME INC
WINFIELD, AL
*X1 DESCRIPTION NOT AVAILABLE -Y1 DESCRIPTION NOT AVAILABLE APA MONOTONE PAINT
CBA STRAIGHT BACK BENCH SEAT CGX RR HEAD RESTRAINTS OUTBOARD SEATING DCB
EPD 2.5L I4 MPI ENGINE GAC TINTED GLASS WINDOWS GEC FRONT LEFT SIDE SLIDING WINDOW
HCC   JAY DO NOT USE - SEE JP, KA CLASSES JFH TACHOMETER
JGB   LAP SHIFT INDICATOR WARNING LAMP LMA HALOGEN HEADLAMPS
MBJ BLACK FRONT BUMPER MDA FRONT LICENSE PLATE BRACKET NAE CALIFORNIA EMISSIONS
PE4 Colorado Red QE4 Colorado Red TBG COMPACT SPARE TIRE
WMC OPEN
  • 1 month later...
Wow! Very cool! I'll have to read up a bit more on how to read this table. Some of this stuff is Greek to me. But I will say that I still have a bench seat, and my MJ did come with a compact spare tire, that I still have (although there is a full size one tucked up under the bed now).
One more thing I will say: My MJ may have come all the way from Alabama, but it has been in California for quite a while. When I bought the truck, it came with a blue license plate with yellow numbers/letters. A quick Google search indicates that the state stopped issuing those with any regularity around 1986 or '87.
I just went to the listed manufacturer's website. I'm thinking about giving them a call. It seems like they have only ever really made RVs. Is it possible that they could have taken a contract to build Jeeps to be sold elsewhere? Or maybe I
A two questions and an observation:
1) Does someone have a key for what all the abbreviations mean? I've been Googling around to no avail.
2) Does GEC refer to the rear window? My current rear window is a solid pane.
3) If this thing had tinted windows at some point, it definitely doesn't anymore. Although, sometimes when I look closely, it does seem like maybe they were a bit smokier in the past.
I wouldn't look into it that much. Chrysler reused a lot of the codes over the last few decades.
tinted windows doesn't refer to what we normally think of with the plastic sheet stuck to it, it's just that the glass has a slight tint built into it.  as soon as you see a plain glass window you'll instantly understand.  :L:
GEC is likely a reused code and those words apply to a later model Chrysler product.  and those 3 letter codes aren't abbreviations, they are just random letters.
there should be WAY more codes for your truck, but a ton of data for the AMC years was lost before they got into the chrysler computer system. if you go look at a 92's build sheet you'll see what I mean. :(
