jeeper_chiefb Posted Monday at 02:29 PM Share Posted Monday at 02:29 PM I picked up this truck for around-town parts runs and to keep my Ram 2500 parked. I've never seen a Comanche with a flatbed and I'm hoping to use the bed for axles, tires and such for my jeep projects. TBI 2.5L, AX-5. At some point in life it was converted 2wd to 4wd with a cable-actuated Dana30 and a 207 t case. It ran like crap, barely idles, power steering leaks, valve cover leaks, but it was only 1500$ on FB marketplace. Link to comment Share on other sites More sharing options...
jeeper_chiefb Posted Tuesday at 04:41 PM Author Share Posted Tuesday at 04:41 PM I began engine troubleshooting by installing a new fuel filter and fuel pump. That worked for one short drive. I replaced the Idle Control Valve, as well as most of the wiring to clean grounds. Another short drive and it died, no start. I kept throwing parts at it such as a crankshaft position sensor and ignition module, and it drove again.... about 4 miles. Finally I took it to TimBukThree Automotive in Westcliffe, CO who works on CJs, YJs, XJs and MJs regularly. He found the ECU was failing and replaced it. It runs great now. Link to comment Share on other sites More sharing options...
eaglescout526 Posted Tuesday at 06:11 PM Share Posted Tuesday at 06:11 PM ECU failing huh. That’s a new one. Link to comment Share on other sites More sharing options...
jeeper_chiefb Posted Wednesday at 02:33 PM Author Share Posted Wednesday at 02:33 PM I've put just over 2k miles on it since replacement and it's been great. Link to comment Share on other sites More sharing options...
jeeper_chiefb Posted Wednesday at 03:03 PM Author Share Posted Wednesday at 03:03 PM The 29 year old interior definitely needs some help to improve the comfort. The sagging bench seat was the biggest problem. I pulled it out and vacuum years of grub from the floor. Also put in a new starter. Link to comment Share on other sites More sharing options...
89 MJ Posted Wednesday at 03:54 PM Share Posted Wednesday at 03:54 PM I hope you pulled up the vinyl flooring too to check out the condition of the floors. I don't think I've ever seen a truck with the vinyl floor that didn't need floor work. Looks like a pretty good truck though. Also, what makes you think that it was two wheel drive originally? I believe that 86s still had the NP207 and the cable actuator on the front axle could have just been to delete the factory CAD stuff. Link to comment Share on other sites More sharing options...
GonzoTheGreat Posted Wednesday at 04:03 PM Share Posted Wednesday at 04:03 PM 21 hours ago, eaglescout526 said: ECU failing huh. That’s a new one. I lost a remix ECU once after doing some welding on the rear bumper. Battery was disconnected, but ECU was not. I learned the hard way to unplug the ECU next time. I bet someone did some welding on the flatbed while it was attached to the vehicle. The Comanche looks great! What a good deal! I bet it will make a great run-around-town truck. Link to comment Share on other sites More sharing options...
jeeper_chiefb Posted Wednesday at 06:30 PM Author Share Posted Wednesday at 06:30 PM 2 hours ago, 89 MJ said: I hope you pulled up the vinyl flooring too to check out the condition of the floors. I don't think I've ever seen a truck with the vinyl floor that didn't need floor work. Looks like a pretty good truck though. Also, what makes you think that it was two wheel drive originally? I believe that 86s still had the NP207 and the cable actuator on the front axle could have just been to delete the factory CAD stuff. Yes, the drivers floor pan is rotted out and I've ordered a replacement floor. On the to do list to weld it in. The previous owner told me it had been converted from 2wd, but he didn't say he did it. Maybe he was mistaken, either way I plan to replace the front axle and transfer case. Link to comment Share on other sites More sharing options...
jeeper_chiefb Posted Wednesday at 06:33 PM Author Share Posted Wednesday at 06:33 PM 2 hours ago, GonzoTheGreat said: I lost a remix ECU once after doing some welding on the rear bumper. Battery was disconnected, but ECU was not. I learned the hard way to unplug the ECU next time. I bet someone did some welding on the flatbed while it was attached to the vehicle. The Comanche looks great! What a good deal! I bet it will make a great run-around-town truck. Good to know. I may one day weld-on frame stiffeners and I will be sure to unplug the ECU to do so. Link to comment Share on other sites More sharing options...
89 MJ Posted Wednesday at 06:39 PM Share Posted Wednesday at 06:39 PM That sounds about right for the floors. Link to comment Share on other sites More sharing options...
jeeper_chiefb Posted Wednesday at 06:47 PM Author Share Posted Wednesday at 06:47 PM I've had some old Corbeau sport seats that I took out of my YJ and I recently learned they make a brackets to install them in a MJ. So I ordered a pair and they bolt right in with no problems at all. Link to comment Share on other sites More sharing options...
