1J7FJ36L7LL101787
WAEMID IV
1990 Jeep Comanche
4.0L / AW4 / 4x4 / Dana 35 / Long Bed
Current Location: Nekoosa Auto Iron and Metal (Wisconsin Rapids)
Status: Parted out in junkyard
This yard has 4 MJs. I shall add them to this registry for documentation purposes. This is MJ 2, which is their only 4.0L-equipped one. It has cruise control, command-trac, the opening rear window, and was a column shift. It also oddly has headrests, which I've never seen on the bench seat before.
BODY: JL62
BUILD: 07/17/89
SELLING DEALER: SCHAEFER MOTOR SALES
RACINE, WI
*X1 DESCRIPTION NOT AVAILABLE -H9 DESCRIPTION NOT AVAILABLE ADLA SKID PLATE GROUP
ALN   ARL   BAYP 105 AMP ALTERNATOR
BCYP 95 AMP BATTERY CBAP STRAIGHT BACK BENCH SEAT CKAP CARPET
DGB ALL 4-SPEED AUTOMATIC TRANSMISSIONS DHTP SHIFT-ON-THE-FLY,P/TIME T/CASE EAAC ALL ENGINES
EAFC   ERB 4.0L I6 MPI ENGINE GFDA REAR SLIDING WINDOW
GRZP LEFT REMOTE MIRROR GSZP RIGHT REMOTE CONTROL MIRROR GTZA MANUAL REMOTE MIRRORS
HAA AIR CONDITIONING JHAA VAR INTERMITTENT WINDSHIELD WIPERS JJAP CIGAR LIGHTER
KKGP DESCRIPTION NOT AVAILABLE K2XP STRIPE/BADGE/MOLDING/COLOR MBJP BLACK BUMPER
MDAP FRONT LICENSE PLATE BRACKET MFGP HEADLAMP BEZEL MHAP BLACK WINDSHIELD MOLDINGS
MMKP   NHM SPEED CONTROL PX8
RAAC ALL RADIO EQUIPPED VEHICLES RAFA OPEN RCDP 4 SPEAKERS
SCEP STEERING WHEEL SUA TILT STEERING COLUMN TAAC ALL TIRES
TBBA FULL SIZE SPARE TIRE TMWA 18 TIRES WJDP WHEELS
WLYC ALL STEEL WHEELS YGEA 5 ADDITIONAL GALLONS OF GAS Z01P REAR SPRING GROUP I
Z67P LEFT FRONT SPRING GROUP XVI Z86P RIGHT FRONT SPRING GROUP XV 5KNA
APAS MONOTONE PAINT BGAS POWER FRONT DISC/REAR DRUM BRAKES CSRS DO NOT USE - SEE CLASS JV
DGSS 4-SPEED AUTOMATIC AW4 TRANSMISSION DHNS COMMAND-TRAC PART TIME 4WD SYSTEM DJHS 230MM FRONT AXLE
DMDS 3.55 REAR AXLE RATIO DRJS DANA 35 REAR AXLE GACS TINTED GLASS WINDOWS
GBBS TINTED WINDSHIELD GLASS GCBS FRONT DOOR TINTED GLASS GEHS FIXED DOOR VENT GLASS
GNAS REAR VIEW DAY/NIGHT MIRROR JAZS DO NOT USE - SEE JP, KA CLASSES JCAS 85 MPH PRIMARY SPEEDOMETER
K3XS STRIPE/BADGE/MOLDING/COLOR LBCS GLOVE BOX LAMP LCJS OVERHEAD AMBIENT SURROUND LIGHTING
LMAS HALOGEN HEADLAMPS MB1S BLACK FRONT BUMPER MMCS
MMGS BELT MOLDINGS NAAS FEDERAL EMISSIONS NBKS EVAP CONTROL SYSTEM
NF5S 23 GALLON FUEL TANK QX8S BLACK CLEAR COAT SBAS POWER STEERING
SFAS STANDARD DUTY FRONT SHOCK ABSORBERS SGAS STANDARD DUTY REAR SHOCK ABSORBERS TBMS TIRE CARRIER WINCH
XBSS PICKUP BOX YAAS BUILD TO U.S. MKT. SPECIFICATIONS Z5AS GVW/PAYLOAD RATING
1AAS U.S. DEALER RETAIL 155S ZONE 55-MILWAUKEE
