WAEMID IV Posted May 28, 2025 Share Posted May 28, 2025 1990 Jeep Comanche 4.0L / AW4 / 4x4 / Dana 35 / Long Bed Current Location: Nekoosa Auto Iron and Metal (Wisconsin Rapids) Status: Parted out in junkyard This yard has 4 MJs. I shall add them to this registry for documentation purposes. This is MJ 2, which is their only 4.0L-equipped one. It has cruise control, command-trac, the opening rear window, and was a column shift. It also oddly has headrests, which I've never seen on the bench seat before. Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 28, 2025 Share Posted May 28, 2025 90 was the first year for bench with headrests. Not common since everyone jumps at the chance to swap to buckets. Link to comment Share on other sites More sharing options...
Pete M Posted May 28, 2025 Share Posted May 28, 2025 you can easily swap that seatback on to the base of an older bench. all headrest benches should be saved! Link to comment Share on other sites More sharing options...
watchamakalit Posted May 29, 2025 Share Posted May 29, 2025 22 hours ago, Pete M said: you can easily swap that seatback on to the base of an older bench. all headrest benches should be saved! Amen. Link to comment Share on other sites More sharing options...
jdog Posted May 31, 2025 Share Posted May 31, 2025 BODY: JL62 BUILD: 07/17/89 SELLING DEALER: SCHAEFER MOTOR SALES RACINE, WI *X1 DESCRIPTION NOT AVAILABLE -H9 DESCRIPTION NOT AVAILABLE ADLA SKID PLATE GROUP ALN ARL BAYP 105 AMP ALTERNATOR BCYP 95 AMP BATTERY CBAP STRAIGHT BACK BENCH SEAT CKAP CARPET DGB ALL 4-SPEED AUTOMATIC TRANSMISSIONS DHTP SHIFT-ON-THE-FLY,P/TIME T/CASE EAAC ALL ENGINES EAFC ERB 4.0L I6 MPI ENGINE GFDA REAR SLIDING WINDOW GRZP LEFT REMOTE MIRROR GSZP RIGHT REMOTE CONTROL MIRROR GTZA MANUAL REMOTE MIRRORS HAA AIR CONDITIONING JHAA VAR INTERMITTENT WINDSHIELD WIPERS JJAP CIGAR LIGHTER KKGP DESCRIPTION NOT AVAILABLE K2XP STRIPE/BADGE/MOLDING/COLOR MBJP BLACK BUMPER MDAP FRONT LICENSE PLATE BRACKET MFGP HEADLAMP BEZEL MHAP BLACK WINDSHIELD MOLDINGS MMKP NHM SPEED CONTROL PX8 RAAC ALL RADIO EQUIPPED VEHICLES RAFA OPEN RCDP 4 SPEAKERS SCEP STEERING WHEEL SUA TILT STEERING COLUMN TAAC ALL TIRES TBBA FULL SIZE SPARE TIRE TMWA 18 TIRES WJDP WHEELS WLYC ALL STEEL WHEELS YGEA 5 ADDITIONAL GALLONS OF GAS Z01P REAR SPRING GROUP I Z67P LEFT FRONT SPRING GROUP XVI Z86P RIGHT FRONT SPRING GROUP XV 5KNA APAS MONOTONE PAINT BGAS POWER FRONT DISC/REAR DRUM BRAKES CSRS DO NOT USE - SEE CLASS JV DGSS 4-SPEED AUTOMATIC AW4 TRANSMISSION DHNS COMMAND-TRAC PART TIME 4WD SYSTEM DJHS 230MM FRONT AXLE DMDS 3.55 REAR AXLE RATIO DRJS DANA 35 REAR AXLE GACS TINTED GLASS WINDOWS GBBS TINTED WINDSHIELD GLASS GCBS FRONT DOOR TINTED GLASS GEHS FIXED DOOR VENT GLASS GNAS REAR VIEW DAY/NIGHT MIRROR JAZS DO NOT USE - SEE JP, KA CLASSES JCAS 85 MPH PRIMARY SPEEDOMETER K3XS STRIPE/BADGE/MOLDING/COLOR LBCS GLOVE BOX LAMP LCJS OVERHEAD AMBIENT SURROUND LIGHTING LMAS HALOGEN HEADLAMPS MB1S BLACK FRONT BUMPER MMCS MMGS BELT MOLDINGS NAAS FEDERAL EMISSIONS NBKS EVAP CONTROL SYSTEM NF5S 23 GALLON FUEL TANK QX8S BLACK CLEAR COAT SBAS POWER STEERING SFAS STANDARD DUTY FRONT SHOCK ABSORBERS SGAS STANDARD DUTY REAR SHOCK ABSORBERS TBMS TIRE CARRIER WINCH XBSS PICKUP BOX YAAS BUILD TO U.S. MKT. SPECIFICATIONS Z5AS GVW/PAYLOAD RATING 1AAS U.S. DEALER RETAIL 155S ZONE 55-MILWAUKEE Link to comment Share on other sites More sharing options...
socalsam Posted June 6, 2025 Share Posted June 6, 2025 Please save that bench Link to comment Share on other sites More sharing options...
