Need help. Bucking loss of power.
Hi I have a 87 2.5l base model, long bed, 5 speed 4WD. A while back after driving for a bit it used to start to buck but if I turned it off and on it usually stopped. I then changed the oil, coolant temp sensor for the ECU and topped off the coolant. The first drive after that after about 5 minutes it starts to buck then lose power. The engine does not shut off I just get nothing when hitting gas. If I turn it off and let it sit for a while it will drive for another 5-10 minutes before happening again. I then replaced water pump, fan clutch, thermostat, all radiator hoses added an inner spring to lower hose, serpentine belt, both coolant sensors, crankshaft sensor and MAP sensor. Still having the same problem. I’m inexperienced but love the truck and have enjoyed working on it but very frustrating having nothing work. Any help is appreciated
What happens if you cycle the key to prime the fuel system a few times immediately after it does some of its bucking? I wonder if your fuel pump is on its way out.
I have not tried. So you’re saying once it starts to buck. Turn it off and cycle the key. And if the bucking stops it’s a fuel pump problem?
If that doesn't fix it, next time it happens, check for spark. It is getting air, so it either must lose fuel or spark.
This sounds very similar to an issue my parent's ZJ had back in the day.  Turned out to be a bad O2 sensor combined this a cracked exhaust header (4.0L).  A new O2 sensor fixed it.
Find it weird the bucking worsened and loss of power after the oil change and swapping the coolant sensor. Thats why I flushed and did all the work to the cooling system. Thought maybe I got air trapped or something.
Oil nor coolant changes would cause the engine to do this. Something electrical would do this related to the fuel and sensors.
now you changed the coolant sensor. Which one?
Now the only way coolant could do this is if the head gasket has failed and is getting into the combustion chambers.
 At first I replaced the one for the ECU. Since then I replaced the one for the gauge because the temp gauge did not work and still doesn’t after changing. Ok glad it shouldn’t have anything to do with that. At least flushing the coolant made me see the metal shaving from the water pump. That’s why I replaced it. The pump was in bad shape
Replaced most sensors already might as well give that a try. Thanks
7 hours ago, eaglescout526 said:
For the gauge, did you get the ‘sensor’ or did you get the one labeled as ‘sender’?
Sender, Crown Auto 53005309.
the rpm gauge the temp gauge and the odometer don’t work. Everything else on the cluster does.
You need the sensors for the gauge not sender. Sender is for the lights.
tach gets its signal straight from the coil and the Speedo is cable driven. Speedo itself could be busted or the cable is messed up. Or the gear in the transmission and or transfer case could no longer be making contact.
Where do the sensors for the gauge go? The one I replaced is on the top of the block back driver side. Do you know a part number?
If these don't fix it, I have an idea what it could be.
It's a PITA to diagnose but if you have a multi-meter I can show you what my 4.0 with these symptoms was.
I got a multimeter and I’m all ears
OP has a 2.5L, but I’m curious if you’re experience will translate
I basically had a bad solder joint that fed both my tps and map in my main wiring harness. Was able to track it down using a wiring diagram after seeing my TPS +5V was dipping to 1.7-2.7V while the engine was running (and only while plugged it....unplugged there was no electrical load on the solder joint so I measured 5VDC every time I unplugged the connector.
When you changed the coolant sensor, you probably moved/jostled/pushed on that wiring harness if it's like the 4.0 in any way.
Feel free to call me, I have every manual made for the 91 & 92 model year Jeeps bc of this issue.... not sure how much the 2.5L changed after the switch to Chrysler but I've got ADHD and a decent internet connection if the manuals don't cut it.
Not 100% sure but this definitely sounds like an electrical issue and I've gotten pretty good at those 😁
Fix is page 5 of this thread. I was a little inactive for a while and it kinda got hijacked but the info is in there.
thank you I’ll try to give it a shot this week. I read the whole thread and it very interesting. Seems very similar. Just wondering if the 2.5l renix will be different. Does this look similar to your harness?
1 hour ago, eaglescout526 said:
2.5L Renix has an ISA. It’s different from the 4.0 and later HO set up with the IAC.
I love when everyone assumes the 2.5L shares the same set up for 4.0 Renix when they were never the same to begin with. Also grinds my gears too.
Thanks yea it’s hard to find solid info
