joeCor
joeCor's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. When I pulled the old pump it had no strainer.
  2. I bought the Carter p74155 pump. It is way to big and the strainer that it came with fits to loose to connect. Think I’m going to get the Bosch 69302. Looks like it doesn’t come with a strainer. Anyone know which strainer to get? 87 longbed 2.5L base
  3. Didn’t want to start a new topic if I don’t gotta but can any one tell me what this is and why it seems like something is missing? Also near it are these wires that are all melted together. I’ll include a pic of the harness it goes to in the passenger side of the engine bay and point out the harness it goes to under the truck. I’d appreciate any info👍
  4. Got the tbi out and goi g to try to remove the screw today. Can anyone tell me what this sensor is?
  5. Thanks for all the replies. First step is trying to get the damn TBI out. Having a hard time getting to two of the mounting bolts.
  6. Back pinning while running yes. And I wiggled them with no change
  7. I was replacing my TPS, I removed the top screw and the tps fell off. The bottom screw had no head and a small stud left. No clue how long it’s been like that. I tried pb blaster, heat and needle nose vice grips but wouldn’t come out. Now it’s flush. Any ideas?
  8. Thanks yea it’s hard to find solid info
  9. Also, does my system have a IAC? Or is it just the ISC? Seeing contradicting info.
  10. I got a multimeter and I’m all ears
  11. Where do the sensors for the gauge go? The one I replaced is on the top of the block back driver side. Do you know a part number?
  12. Sender, Crown Auto 53005309. the rpm gauge the temp gauge and the odometer don’t work. Everything else on the cluster does.
  13. Replaced most sensors already might as well give that a try. Thanks
