A-man930 Posted May 2, 2025 Share Posted May 2, 2025 How much does the cab flex relative to the chassis? What are the consequences of bracing the back of the cab? I’ll start with the disclaimer that I am not building a proper roll cage – I’m approaching this as a “cab saver” that could probably save my life in a pinch. This means that there are compromises from structural “ideals” in the name of aesthetics. Here are my requirements: Minimal “verticals” to sit outboard of the body. Bed will be in the factory position (I am open to a < 1/2” adjustment rearward by slotting the bolt holes on the chassis side.) Bed will have a tonneau cover; no pass throughs into the bed. My solution for the rear is a lower support structure fabricated from .188” wall 2x1 rec tubing. This will sandwich between the cab and the bed and provide “perches” below the rear glass for the tubular cage. It will tie into my tube rockers and the top of the frame rails. What I can't decide is if I should I weld this structure to the back of the cab, or leave it freestanding. I'm prone to weld it, but should I worry about inducing some kind of stress elsewhere? In a "lean against a a tree" scenario, am I asking to bust the glass out? At full flex, will the welds to the rockers and the frame be stressed and crack? Link to comment Share on other sites More sharing options...
neohic Posted May 2, 2025 Share Posted May 2, 2025 If it were me, I’d weld everything together. Especially in a case like yours were there’s so much additional plating and material already, I wouldn’t worry about having too much rigidity. Any seams, I’d cover with a non hardening sealer. Link to comment Share on other sites More sharing options...
A-man930 Posted May 2, 2025 Author Share Posted May 2, 2025 1 hour ago, neohic said: If it were me, I’d weld everything together. Especially in a case like yours were there’s so much additional plating and material already, I wouldn’t worry about having too much rigidity. Any seams, I’d cover with a non hardening sealer. Good point. There is a lot of reinforcing already: Link to comment Share on other sites More sharing options...
jeff351 Posted May 2, 2025 Share Posted May 2, 2025 I'm thinking that if you weld it to both the frame and the cab, you should be fine. I like where you are going with this idea. Link to comment Share on other sites More sharing options...
A-man930 Posted May 5, 2025 Author Share Posted May 5, 2025 On 5/2/2025 at 10:50 AM, jeff351 said: I'm thinking that if you weld it to both the frame and the cab, you should be fine. I like where you are going with this idea. I'm all but convinced I'm going to weld it. Thanks. Link to comment Share on other sites More sharing options...
A-man930 Posted May 14, 2025 Author Share Posted May 14, 2025 Mocked up the basics. Link to comment Share on other sites More sharing options...
75sv1 Posted May 16, 2025 Share Posted May 16, 2025 I think I'd put in cross bracing. Link to comment Share on other sites More sharing options...
A-man930 Posted May 16, 2025 Author Share Posted May 16, 2025 1 hour ago, 75sv1 said: I think I'd put in cross bracing. Yes. Gravity didn't allow me to mock those up. Link to comment Share on other sites More sharing options...
A-man930 Posted May 20, 2025 Author Share Posted May 20, 2025 Added a little meat to the top of the frame. Link to comment Share on other sites More sharing options...
A-man930 Posted May 20, 2025 Author Share Posted May 20, 2025 Link to comment Share on other sites More sharing options...
A-man930 Posted May 21, 2025 Author Share Posted May 21, 2025 Link to comment Share on other sites More sharing options...
A-man930 Posted May 22, 2025 Author Share Posted May 22, 2025 All tacked up. The horizontal piece across the bottom is a temporary brace that'll get cut off after finish welding. Link to comment Share on other sites More sharing options...
A-man930 Posted June 1, 2025 Author Share Posted June 1, 2025 Got her all welded up. With help, we managed to keep it straight! Link to comment Share on other sites More sharing options...
ThatJeepGuy Posted June 16, 2025 Share Posted June 16, 2025 Not to be the stick in the mud... but id refrain from welding the cab to the structure. Despite the level of plating you have going on (i absolutely digging that inner brace btw) I think your unibody is still going to see twist and that would transition into your cabs sheet metal, over time that fatigue and stress will start splitting seams and it won't be obvious where. I'd argue unless you have some perpendicular ties to your structure to counter the push/pull from flexing it will just twist against the back of the cab. My brother plated his unibody (XJ unibody) from tip to tail with 3/16's and some sections with 1/4". No interior cage nothing vertical and over the last 8 years we've watched the seams in the roof of the body slowly seperate. At this point the seams around his hatch mounts and rear qtr glass have visible air between the sheet metal. Same around the rear door seams in a couple spots. Granted this jeep is a LCG build on 4" and 39 tires but the twist still exists. Put the jeep on an rti ramp to your max and drop the tailgate/open your doors, open the hood, if you see deflecting in latching those then you absolutely still have flex in your total unibody Link to comment Share on other sites More sharing options...
A-man930 Posted June 28, 2025 Author Share Posted June 28, 2025 On 6/16/2025 at 6:59 PM, ThatJeepGuy said: Not to be the stick in the mud... but id refrain from welding the cab to the structure. Despite the level of plating you have going on (i absolutely digging that inner brace btw) I think your unibody is still going to see twist and that would transition into your cabs sheet metal, over time that fatigue and stress will start splitting seams and it won't be obvious where. I'd argue unless you have some perpendicular ties to your structure to counter the push/pull from flexing it will just twist against the back of the cab. My brother plated his unibody (XJ unibody) from tip to tail with 3/16's and some sections with 1/4". No interior cage nothing vertical and over the last 8 years we've watched the seams in the roof of the body slowly seperate. At this point the seams around his hatch mounts and rear qtr glass have visible air between the sheet metal. Same around the rear door seams in a couple spots. Granted this jeep is a LCG build on 4" and 39 tires but the twist still exists. Put the jeep on an rti ramp to your max and drop the tailgate/open your doors, open the hood, if you see deflecting in latching those then you absolutely still have flex in your total unibody I've been chewing on this for a bit. You've put my concerns into words. On your brother's rig, how much of this would have been happening anyways? How hard is it wheeled? Explain what you mean by "perpendicular ties" Link to comment Share on other sites More sharing options...
A-man930 Posted March 10 Author Share Posted March 10 Finally... Link to comment Share on other sites More sharing options...
A-man930 Posted March 11 Author Share Posted March 11 I decided to do some kickers down to the frame. Even though they're short, they'll surely help limit some twist. Link to comment Share on other sites More sharing options...
A-man930 Posted March 12 Author Share Posted March 12 Working to get this structure flush up against the back of the cab. I used a bunch of clamps across the top and made some pushers for the bottom. Does anyone remember the first time you discovered there isn't a single plumb wall or square corner in your home? Yeah, I feel like I'm discovering all of AMC's production sins, but I know it's really a non-issue. Link to comment Share on other sites More sharing options...
neohic Posted March 12 Share Posted March 12 11 hours ago, A-man930 said: Does anyone remember the first time you discovered there isn't a single plumb wall or square corner in your home? Yeah, I feel like I'm discovering all of AMC's production sins… Pretty much any time I see a factory weld. Link to comment Share on other sites More sharing options...
A-man930 Posted March 12 Author Share Posted March 12 11 minutes ago, neohic said: Pretty much any time I see a factory weld. Dude. Link to comment Share on other sites More sharing options...
A-man930 Posted March 13 Author Share Posted March 13 Lots more to go, but it's holding itself in place now. It's already SOLID Link to comment Share on other sites More sharing options...
