Parking Brake Stop
My e-brake goes up with an aggressive whack when I release it. Is there supposed to be a rubber stop here? It looks like there is a hole for one to mount. Anyone know where I can get one that'll fit? Thanks!
3 hours ago, pizzaman09 said:
I always put my foot on the brake pedal and lift it carefully so it doesn't go whak.
:yeahthat: This is a good idea and the same things I do after rebuilding the parking brake. Really helps the pawl and sprocket
Likewise I pull the handle when I set the pedal so as to not wear out the pawl.  I was fortunate to find a replacement assembly for mine as it was completely destroyed when I purchased my truck.  I don't need it wearing out.
Also I've wacked my hand a few times pulling the lever and letting the pedal hit my hand, no fun.
  • 1 month later...
1 hour ago, ghetdjc320 said:
I found one that fit great at Ace on the hardware section. It was a Hillman part.
Hmm I'll keep an eye out at ace next time I'm there. Thanks for the tip
