JimManche17 Posted March 24, 2025 Share Posted March 24, 2025 I have an 88 2wd with a Rusty’s off-road 4.5 inch lift kit. Does anyone know what the biggest size tire I can fit with minimal cutting I have 17 inch rims on now with 1.5 in spacers. Link to comment Share on other sites More sharing options...
89 MJ Posted March 24, 2025 Share Posted March 24, 2025 A large factor in this is the backspacing of the wheel, but I believe that 33s fit with a 4.5” lift. Link to comment Share on other sites More sharing options...
camjeep3 Posted March 24, 2025 Share Posted March 24, 2025 Wheel backspacing width and tire width make a big difference. 10.50s will probably fit easy with the right wheels. I had 33x13.5s on 10" wide wheels and they ate the fenders turning Link to comment Share on other sites More sharing options...
75sv1 Posted March 24, 2025 Share Posted March 24, 2025 I have some metric tires that at between 32 and 33 on a 4.5 lift. This was on a '98 XJ. The tire width is about 10.5. I was using WJ rims. I did have to have the bump stops limit the turning radius a bit. This was with a WJ Big Brake setup. I did not run spacers. I did use WJ hub bearings. Link to comment Share on other sites More sharing options...
DesertRat1991 Posted March 24, 2025 Share Posted March 24, 2025 You can fit up to 33x10.5 without cutting if you properly adjust your bumpstops and turnstops. I'm on metrics that are roughly 32x10.5. Link to comment Share on other sites More sharing options...
75sv1 Posted March 24, 2025 Share Posted March 24, 2025 Mine are 265/70R17 Falken Wild Peaks. Link to comment Share on other sites More sharing options...
PIKE Posted March 25, 2025 Share Posted March 25, 2025 33 inch tires on 4.5 lift. 33-10.5-15 Stock wheels no spacers. Rubicon Express 4.5" front springs. Link to comment Share on other sites More sharing options...
