Gojira94 Posted February 12, 2025 Share Posted February 12, 2025 I have the 'baseball.' As the vehicle was originally built and sold, it had no A/C, no CAD, no cruise, just vacuum to run the heater controls. I'm only adding cruise. Is the 'baseball' tank adequate for these 2 functions, or should I be looking to replace it with the 'football' if I'm adding cruise? Link to comment Share on other sites More sharing options...
89 MJ Posted February 12, 2025 Share Posted February 12, 2025 I would guess that it will be sufficient. My truck had AC and 4wd with the little vacuum reservoir. Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 12, 2025 Share Posted February 12, 2025 Replace with the football from the Renix era if you can. If not, run a second baseball Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted February 12, 2025 Share Posted February 12, 2025 Just would like to add that there are 2 different football reservoirs. One that has 2 sides and 4 ports with internal check valves, not available new. The other is the same size but only has one chamber, one port and relies on an external check valve to function, this one is available new. Link to comment Share on other sites More sharing options...
Gojira94 Posted February 12, 2025 Author Share Posted February 12, 2025 Thanks all for the replies. I'll give the one I've got a go, if it doesn't seem adequate, I think the one-chamber football is what I'll look for. Link to comment Share on other sites More sharing options...
89 MJ Posted February 12, 2025 Share Posted February 12, 2025 3 minutes ago, Gojira94 said: Thanks all for the replies. I'll give the one I've got a go, if it doesn't seem adequate, I think the one-chamber football is what I'll look for. If they don’t think it’ll work, you should probably disregard what I said . That said might be worth a shot if it’s not much more work. Link to comment Share on other sites More sharing options...
Gojira94 Posted February 12, 2025 Author Share Posted February 12, 2025 1 minute ago, 89 MJ said: If they don’t think it’ll work, you should probably disregard what I said . That said might be worth a shot if it’s not much more work. Well, it's an easy thing to swap, even with a completely assembled vehicle. I'm all over the map right now, pulling together vacuum lines, EVAP, fuel, etc. so I'm trying to sort things that could easily wait into a list. Link to comment Share on other sites More sharing options...
Gojira94 Posted February 18, 2025 Author Share Posted February 18, 2025 Interesting find in the boneyard- a 94 XJ showed up. I snagged a football reservoir with a single port. Just the one port for manifold vacuum. It uses a check valve at the HVAC. This XJ didn't have cruise so the tee where it would have connected was capped. I'd imagine in 94 it would have used a check valve there as well if cruise equipped (no, no check valve for cruise). This XJ had obviously been sitting in a tree row for a while, but it hissed when I disconnected the line from the reservoir. I like the simplicity of the setup, so I'm going to try it out as pulled, with no check valve at the cruise servo. Link to comment Share on other sites More sharing options...
AZJeff Posted February 19, 2025 Share Posted February 19, 2025 On 2/12/2025 at 11:23 AM, Gojira94 said: I have the 'baseball.' As the vehicle was originally built and sold, it had no A/C, no CAD, no cruise, just vacuum to run the heater controls. I'm only adding cruise. Is the 'baseball' tank adequate for these 2 functions, or should I be looking to replace it with the 'football' if I'm adding cruise? The football type reservoir was used on all the later XJ’s. I cannot see how using on an older XJ or MJ would cause any issues in terms of storing residual vacuum. Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 19, 2025 Share Posted February 19, 2025 18 hours ago, Gojira94 said: Interesting find in the boneyard- a 94 XJ showed up. I snagged a football reservoir with a single port. Just the one port for manifold vacuum. It uses a check valve at the HVAC. This XJ didn't have cruise so the tee where it would have connected was capped. I'd imagine in 94 it would have used a check valve there as well if cruise equipped. This XJ had obviously been sitting in a tree row for a while, but it hissed when I disconnected the line from the reservoir. I like the simplicity of the setup, so I'm going to try it out as pulled, with an identical check valve at the cruise modulator. If these can be used on Renix easily, then I’ve got two of them I’d like gone from my stash. Link to comment Share on other sites More sharing options...
Gojira94 Posted February 19, 2025 Author Share Posted February 19, 2025 On 2/19/2025 at 10:44 AM, eaglescout526 said: If these can be used on Renix easily, then I’ve got two of them I’d like gone from my stash. It looks like in 91 they just tried to simplify the setup with a single vacuum line for the tank and accessories fed by it, all the way through 2001 on the XJ. Electrical control of the servo changed from 5 wires to 4 to operate from VSS signal feedback in the ECU, but it was still vacuum modulated. It appears no check valve was fitted for the cruise servo vacuum source, just for the HVAC vacuum controls. Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 19, 2025 Share Posted February 19, 2025 10 minutes ago, Gojira94 said: It looks like in 91 they just tried to simplify the setup with a single vacuum line for the tank and accessories fed by it, all the way through 2001 on the XJ. Electrical control of the servo changed from 3 wires to 4 to operate from VSS signal feedback in the ECU, but it was still vacuum modulated. It appears no check valve was fitted for the cruise servo vacuum source, just for the HVAC vacuum controls. Suppose one could do this to a Renix set up. Don’t see why not but that canister must hold some good vac to operate HVAC and cruise. Link to comment Share on other sites More sharing options...
Gojira94 Posted February 19, 2025 Author Share Posted February 19, 2025 Not sure for a Renix vehicle equipped with CAD and cruise. But it might work for all 3 systems with an additional T and feed line to the CAD added in. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted February 19, 2025 Share Posted February 19, 2025 47 minutes ago, Gojira94 said: Which part is the check valve? 15? Link to comment Share on other sites More sharing options...
Gojira94 Posted February 19, 2025 Author Share Posted February 19, 2025 12 minutes ago, Eagle_SX4 said: Which part is the check valve? 15? Yes. Link to comment Share on other sites More sharing options...
