Gojira94 Posted January 23, 2025 Share Posted January 23, 2025 Part # 27 - 52003939: I think this is used for manual trans applications but I'm not 100% sure. If so, how thick is it? I made one from 1/4" HDPE just in case. Link to comment Share on other sites More sharing options...
Pete M Posted January 23, 2025 Share Posted January 23, 2025 #27 in the image? the one that goes with the automatic? Link to comment Share on other sites More sharing options...
89 MJ Posted January 23, 2025 Share Posted January 23, 2025 I don't think that is for manual transmissions. When I pulled my AX-15 out of a 97 XJ, it didn't have that. My MJ has been probably 10,000 miles without one with no issue. Link to comment Share on other sites More sharing options...
Gojira94 Posted January 23, 2025 Author Share Posted January 23, 2025 30 minutes ago, Pete M said: #27 in the image? the one that goes with the automatic? Yeah, the diagram seems to indicate it's for auto, but I filtered the lookup for ERH/DDQ/4WD and it shows in the list of applicable parts. That's why I'm asking, if anyone has a late 89-92 4.0/AX-15 or ever seen a rig that came with this spacer. Link to comment Share on other sites More sharing options...
Gojira94 Posted January 23, 2025 Author Share Posted January 23, 2025 2 minutes ago, 89 MJ said: I don't think that is for manual transmissions. When I pulled my AX-15 out of a 97 XJ, it didn't have that. My MJ has been probably 10,000 miles without one with no issue. Thanks for confirming. The crossmember I snagged was from a 96 XJ and I didn't see one on that either. But you never know with older vehicles, people change out mounts and sometimes forget to put everything back. FWIW, if you have an AW4 and it's missing, 1/4" HDPE makes a pretty decent substitute if you don't have 1/4" mild steel plate handy. Link to comment Share on other sites More sharing options...
89 MJ Posted January 23, 2025 Share Posted January 23, 2025 16 minutes ago, Gojira94 said: Thanks for confirming. The crossmember I snagged was from a 96 XJ and I didn't see one on that either. But you never know with older vehicles, people change out mounts and sometimes forget to put everything back. You bet. The XJ was a 313k mile trail rig, so I can't guarantee that it hadn't been messed with either, but I would doubt that it was being that 2nd gear was out of it and it had stock gearing. I don't think it was messed with at all, just was abused. Now that I think about it more, my 90 MJ (that I forgot I owned at one point in my earlier post) had an AX-15 and definitely did not have the cushion. Granted again, it was a 238k mile truck, but seemed all stock to me. Link to comment Share on other sites More sharing options...
Gojira94 Posted January 23, 2025 Author Share Posted January 23, 2025 This truck is a jigsaw puzzle with no box/ picture. And half the pieces were missing when I got it... Link to comment Share on other sites More sharing options...
89 MJ Posted January 23, 2025 Share Posted January 23, 2025 Nothing like taking an already daunting task and making it even more difficult Link to comment Share on other sites More sharing options...
fiatslug87 Posted January 23, 2025 Share Posted January 23, 2025 My ‘90 does not have it and I’m the original owner, clutch replacement was done by me and I highly doubt I didn’t reinstall it. Link to comment Share on other sites More sharing options...
Gojira94 Posted January 23, 2025 Author Share Posted January 23, 2025 8 minutes ago, fiatslug87 said: My ‘90 does not have it and I’m the original owner, clutch replacement was done by me and I highly doubt I didn’t reinstall it. Thanks! Link to comment Share on other sites More sharing options...
BillsMJ Posted April 21, 2025 Share Posted April 21, 2025 The spacer is .175 Link to comment Share on other sites More sharing options...
BillsMJ Posted April 21, 2025 Share Posted April 21, 2025 There wasn't a spacer between cross member and mount. There is a spacer between transmission and and trans mount. .175 Link to comment Share on other sites More sharing options...
Gojira94 Posted April 21, 2025 Author Share Posted April 21, 2025 2 hours ago, BillsMJ said: There wasn't a spacer between cross member and mount. There is a spacer between transmission and and trans mount. .175 First, welcome to the forum - the (IMHO) greatest MJ site on the planet... please add your VIN to the registry so it can be counted and recognized. I can confirm the mount plate bolted to the bottom has that riser layer on mine as well. But I think that's just part of the mount plate itself. I did keep the spacer I made handy in case I want to install it due to trans cushion sag under the weight of the transfer case. It's a common complaint of the current aftermarket/ parts house trans mounts. Link to comment Share on other sites More sharing options...
Flexj Posted April 22, 2025 Share Posted April 22, 2025 Ive had like three ax15 XJs/MJs and never seen that spacer in place before... Not saying its for sure not supposed to be there, but it definitely looks like its for the auto in the diagram. Link to comment Share on other sites More sharing options...
Htchevyii Posted April 23, 2025 Share Posted April 23, 2025 On 4/21/2025 at 7:52 AM, Gojira94 said: First, welcome to the forum - the (IMHO) greatest MJ site on the planet... please add your VIN to the registry so it can be counted and recognized. I can confirm the mount plate bolted to the bottom has that riser layer on mine as well. But I think that's just part of the mount plate itself. I did keep the spacer I made handy in case I want to install it due to trans cushion sag under the weight of the transfer case. It's a common complaint of the current aftermarket/ parts house trans mounts. The new Anchor trans mount on my Comanche was so soft that the transmission would bounce around and pop out of 2nd gear off road. After the first trip, I replaced it with an OEM mount, (still available as of 18 MOS ago). That solved the problem. Link to comment Share on other sites More sharing options...
Gojira94 Posted April 23, 2025 Author Share Posted April 23, 2025 20 minutes ago, Htchevyii said: The new Anchor trans mount on my Comanche was so soft that the transmission would bounce around and pop out of 2nd gear off road. After the first trip, I replaced it with an OEM mount, (still available as of 18 MOS ago). That solved the problem. This is still a concern for me, I'm keeping an eye on it. This is what I'm lusting after for near-future upgrades: https://dbmetalworx.com/4x4-products/Ultimate-UPGRADED-HD-TRANSMISSION-&-MOTOR-COMBO-Kits-Jeep-YJ-XJ-MJ-TJ-&-ZJ-p97355283 Made with a poly durometer on the softer end from what I understand. Link to comment Share on other sites More sharing options...
Htchevyii Posted April 23, 2025 Share Posted April 23, 2025 I tried the Stinky Fab "soft polyurethane" trans mount and MORE, bombproof engine mounts that use Clevite rubber control arm bushings. They rattled my teeth out! I think that it was mostly the engine mounts. https://www.stinkyfab.com/products/sfr-trail-proof-transmission-mount-jeep-xj-cherokee https://mountainoffroad.com/products/bomb-proof-motor-mount-kit-yj-tj-lj-xj?variant=14539007295599&country=US¤cy=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gbraid=0AAAAA-B0w7YHgwve42zGOaOSAvSFsmXux&gclid=CjwKCAjwn6LABhBSEiwAsNJrjsVDPTT-EKkScGWh2SG3zyISvsKAsEs6DSk97DIa22RSUJKb07S-txoCPj4QAvD_BwE Link to comment Share on other sites More sharing options...
Gojira94 Posted April 23, 2025 Author Share Posted April 23, 2025 Yep, you're right. I got confused. The StinkyFab are the ones I wanted, with the softer bushings. Link to comment Share on other sites More sharing options...
