a1awind Posted January 10, 2008 Share Posted January 10, 2008 has anyone ever shot foam insulation into a rust hole then covered it with bondo for a quick fix? the reason i ask is i was talking to a rather mechanically inclined lady about how she got her 89 carolla to pass pa inspection. she sail she had a hole in the rocker so she shot in foam insulation, cut off the excess then bondo-glassed overtop. it sounded like an idea to me. Link to comment Share on other sites More sharing options...
92comanche4x4 Posted January 10, 2008 Share Posted January 10, 2008 I got some foam you spray on i was gona fill my rotted out rockers with is sand it down smothe and use a fiberglass resin over it and sand it it would work great i work at a body shop and my boss said it would work great Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 10, 2008 Share Posted January 10, 2008 As a highly temporary (read, to get you through a VI) repair it'd work great. Longer term? Hell no. There's lots of bad things you can do, and that's right up there... A lot of expanding foams are hydroscopic and cause rust. And you CAN'T bond fiberglass to metal. EVER! A thin applcation of body filler is one thing (guys argue what 'thin' is all the time, but let's say 1/16 - 1/8") as the dissimilar expansion rate does not pose much of a problem as the final product will remain flexible enough. But fiberglass is a whole new animal - it expands very little when heated, and is very rigid even in a thin application. The end result is it will de-bond from ANY metal over time. Link to comment Share on other sites More sharing options...
FxRacing282 Posted January 10, 2008 Share Posted January 10, 2008 and when moisture gets in the foam will act as a sponge and will take forever to dry out, thus causeing more rust in the long run. if you have a rust hole, your best bet is to mig weld some new sheetmetal ondo whatever it is thats rusted. of course cut away, sand and prime before you weld Link to comment Share on other sites More sharing options...
Pete M Posted January 10, 2008 Share Posted January 10, 2008 I know from personal experience that it's a bad, bad, bad thing to do. Made my bedside waaaay worse and rot out faster than before. :( Link to comment Share on other sites More sharing options...
edman2007 Posted January 10, 2008 Share Posted January 10, 2008 My left rear fender is rotting out, the outer part of it has a huge hole above the fender flare (ive already taken them all off) and i was wondering what I should do. I don't have a welder, or really much axcess to one so I'm lost here of what i should do. If I did have a welder I would take my left front fender (dented in the front), cut out a patch and put that on. I was wondering about the whole Easy-Foam thing but i had questions too about the water retention of it. Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 10, 2008 Share Posted January 10, 2008 My left rear fender is rotting out, the outer part of it has a huge hole above the fender flare (ive already taken them all off) and i was wondering what I should do. I don't have a welder, or really much axcess to one so I'm lost here of what i should do. If I did have a welder I would take my left front fender (dented in the front), cut out a patch and put that on. I was wondering about the whole Easy-Foam thing but i had questions too about the water retention of it. Make friends with somebody with a welder... I know, it sounds rather shallow, but there's lots of nice people out there with welders. Link to comment Share on other sites More sharing options...
Pete M Posted January 10, 2008 Share Posted January 10, 2008 Find a local 4x4 club or website. That's how I've found people to do the important welding on my truck. Some will even do it for beer. :D Link to comment Share on other sites More sharing options...
FxRacing282 Posted January 10, 2008 Share Posted January 10, 2008 if you don't have a welder a ball-peen hammer, rivits and a little bondo will work. that would be better then foam anyday Link to comment Share on other sites More sharing options...
edman2007 Posted January 10, 2008 Share Posted January 10, 2008 could you pm me some info on how i should secure some sheet metal to the fender? Link to comment Share on other sites More sharing options...
lower jeep Posted January 11, 2008 Share Posted January 11, 2008 please don't put foam in the bed side, like they said make friends with some one that has a welder because i had a dodge shadow that some one put foam in a rust hole before i got it and had a new paint job on it and with in 3 months it made the hole even bigger. foam is not a good choice for any thing that is going to be exposed to the elements even after drying the foam out and welding new metal in the rust started back before i got rid of the car. Link to comment Share on other sites More sharing options...
Wildman Posted January 11, 2008 Share Posted January 11, 2008 could you pm me some info on how i should secure some sheet metal to the fender? Check out this site, and this link, details on panel repairs ;) http://www.autobodystore.com/door_rust.shtml Link to comment Share on other sites More sharing options...
