Top C Posted January 16, 2025 Share Posted January 16, 2025 The dash indicator broke. Is there an after market replacement or maybe a Ford/Chevy type that would work? Thanks Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 16, 2025 Share Posted January 16, 2025 One inside the cluster or on the column? Link to comment Share on other sites More sharing options...
llhat Posted January 16, 2025 Share Posted January 16, 2025 watching my 89 is still connected, but the collar on the steering column is not connected to the housing for the lever, been that way a long time.... Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 16, 2025 Share Posted January 16, 2025 3 minutes ago, llhat said: watching my 89 is still connected, but the collar on the steering column is not connected to the housing for the lever, been that way a long time.... There should be a clip that attaches to the back side of that collar if it’s the one in the cluster. I have a loose indicator that I can snap a pic of later to show ya. Link to comment Share on other sites More sharing options...
Top C Posted January 16, 2025 Author Share Posted January 16, 2025 Inside the cluster Link to comment Share on other sites More sharing options...
Pete M Posted January 17, 2025 Share Posted January 17, 2025 the tiny cable can indeed break, but it's far more likely that the clip came off. Link to comment Share on other sites More sharing options...
Top C Posted January 17, 2025 Author Share Posted January 17, 2025 Ok I will check that today and hopefully that is what happend. It’s been gradually moving all the way to the left. I’m sorry I didn't mention that part. Link to comment Share on other sites More sharing options...
GonzoTheGreat Posted January 18, 2025 Share Posted January 18, 2025 On 1/17/2025 at 5:02 AM, Top C said: Ok I will check that today and hopefully that is what happend. It’s been gradually moving all the way to the left. I’m sorry I didn't mention that part. That sounds like the clip slipped off. It’s a little tricky getting your fingers in there without taking everything apart. I’ve had the best luck clipping it back on the collar wherever I can, and then pushing the clip with a flat head to adjust the position. Link to comment Share on other sites More sharing options...
llhat Posted January 19, 2025 Share Posted January 19, 2025 anyone know what retains the collar inside of the column near the shifter? Link to comment Share on other sites More sharing options...
