Door Window Replacement
Since we've owned the Comanche, the passenger door window has never worked very well. It needs a new regulator. We recently acquired a door off of a '93 XJ with manual windows for the regulator. Since the windows in that door are a little better than the windows in the MJ we figured we might as well swap those while we were at it. This weekend we disassembled the donor door to remove the regulator, window, triangle window, and weather strip.
BleepinJeep's video was extremely helpful in disassembling everything. Basically, the window comes out last. https://www.youtube.com/watch?v=Pd-8nG7c8b4
However, in the video, he replaces the square and triangle windows with the larger 97+ window and so there are no instructions on how to put the two windows back in. Specifically, we're wondering how to get the square window back in. What we are thinking is install the regulator, put the square window in the bottom of the door, install the triangle window, install the weather strip, then attach the square window to to the regulator. Does that order sound right? Any tips or tricks?
We plan to do this in a shop 350 miles from home when we are doing lifters. So driving home from eastern Idaho in the winter without a window isn't an option. :wink:
10 hours ago, eaglescout526 said:
The order you stated would be the way I’d do it. You can tilt a triangle easier than a square in such a small space.
1 hour ago, M.T.Hands said:
That is the way mine went back together after I repaired the regulators and added vent windows:wink:
Appreciate the feedback that we are on the right track.
I'll post this add on just for fun.  My pass side window crank is stripped out starting about 2" from full down.  Once you go past that spot you have to pull the glass up.  So if you, or your unsuspecting passenger should happen to fully lower the window, you are a bit stuck.  So my solution to date is a trusty piece of 2x6 in the bottom of the door to prevent any accidental full lowering.  Far from stock, and I didn't even use an OEM 2x6, but it does keep my window "roll-upable".:))
that's why mine were "out" for repair, new regulators would be nice, or some concise info on other regulators to use/try, repairing them was a little bit of a "test" and when you flip the cable getting it "clamped" back down, was a little tricky, my first attempt, I did not close up the clamp quite as well as the factory had done and made the clamp not want to freely go through the trac, I was able to form the clamp back to a suitable dimension and side 2 went much better, but be fore-warned, pay attention to how they look during disassembly to ensure they will go through the trac:wink::dunno:
On 12/23/2024 at 10:08 AM, JZLAJeep said:
Install the regulator, put the square window in the bottom of the door, install the triangle window, install the weather strip, then attach the square window to to the regulator.
Did this yesterday. This was a successful order of installation.
