AnotherOldJeepGuy Posted November 16, 2024 Share Posted November 16, 2024 I just replaced my valve cover gasket today. I had a lot of oil leaking, but the engine ran fine. Now I need HELP! I cleaned up the area where the gasket goes so it looked pretty clean both on the engine and on the old valve cover. Now the truck runs very rough, sounds like it has a bad exhaust, and quickly fills my garage with what I believe is probably carbon monoxide! There was a hose that I broke, I believe it is a vacuum hose of some kind. It split as I tried to remove it it out of the valve cover. It split into only two pieces, that part outside the cover and the part just inside the cover. I was able to pull out the piece that stayed in the cover with needle-nose pliers. When it came out it also cracked the plastic pipe at the other end. I temporarily taped it back together, and set the other in in the hole, but it is not held in tight. The only other thing I see is a piece of plastic pipe that seems to go nowhere at one end, that is, I can't see anyplace to connect it. The other end is up by the firewall. My guess is this pipe has been open for a long time, but I can't prove it. I can't see anything else that looks touched, and the two things I mentioned above don't seem to be large enough trouble to totally mess up the engine running, but, they are the only things I can see and the truck is running very rough now. The vacuum hose assembly is available so I'll replace it, but is that hose enough to cause what I have described? If not, any other ideas what has happened? I can't imagine how a valve cover gasket replacement messed up the engine, but something did! Link to comment Share on other sites More sharing options...
Ωhm Posted November 16, 2024 Share Posted November 16, 2024 You ain't going anywhere with that MAP sensor hose disconnected. Should connect up at the base of TB. Look for the other missing end. What's that green thing laying on the heat shield? Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted November 16, 2024 Author Share Posted November 16, 2024 19 minutes ago, Ωhm said: You ain't going anywhere with that MAP sensor hose disconnected. Should connect up at the base of TB. Look for the other missing end. What's that green thing laying on the heat shield? Looks like that green thing is part of a latch. I have hunted but can't see anything to attach that plastic hose to, perhaps someone can post a picture where it goes when it is connected. Link to comment Share on other sites More sharing options...
Ωhm Posted November 16, 2024 Share Posted November 16, 2024 This shows the general area where the vacuum hose goes. That broken tab (green) can/will cause problem later on. Take note. Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted November 16, 2024 Author Share Posted November 16, 2024 Found the connection! Running normal now, thanks. I guess I'll tie wrap the connection with the broken tab so it won't wiggle loose. Link to comment Share on other sites More sharing options...
schardein Posted November 17, 2024 Share Posted November 17, 2024 I just read through this post. I have a couple suggestions. It sounds like you intend to replace the fresh air hose, that is the large hose that connects to the front opening in the valve cover. It is part of the Crankcase Ventilation (CCV) system. That is where fresh air is drawn into the engine. I would also remove and carefully inspect the thinner hose that attaches to the rear hole in the valve cover. That is the vacuum side. It uses a "metered orifice". That metered orifice looks to be white or off-white and plugs into the rubber grommet in the valve cover. Carefully wiggle that out, and disconnect the other end at the intake manifold. Then make sure the line is clear. Blowing through it is a good test. It's common for the orifice to be clogged with carbon. If it is, your CCV system will not work as intended. If it is clogged, soak the orifice in a solvent (brake clean, carb cleaner, PB Blaster) and use something like a paper clip to carefully break up the carbon and clear the orifice. The connector for the MAP sensor (green plastic) can be replaced. The connector is relatively inexpensive. https://www.rockauto.com/en/catalog/jeep,1989,cherokee,4.0l+242cid+l6,1179929,electrical-connector,manifold+pressure+(map)+sensor+connector,2597 Rather than cut and splice the factory wires, I would de-pin the old connector. Working one wire at a time, de-pin one wire from the old connector, de-pin the corresponding wire on the new connector, and place the old free wire in its new home in the new connector. Work through the other two. You'll need a special tool to de-pin the weatherpack connector. There are many choices, here is one: https://www.amazon.com/Weather-Pack-Terminal-Extractor-Tool/dp/B0040CRUNO/ref=sr_1_12_sspa?crid=3W3YW97MYOIWC&dib=eyJ2IjoiMSJ9.-guaGmIeFsBVVD4lcyjMg9is5378Y3SzA7C2yoU-Cr7YnIGdbKl8Ds_4rdCzmh86862Jv4GhEgRSdxCXpJJD63Q0KG_4fcpSdkJpWe6fvLg.AeY6QI9by4LhAzS2SZPvta_7buxqbLPpYJ4z8IuMlvw&dib_tag=se&keywords=12014012&qid=1731885133&sprefix=12014012%2Caps%2C283&sr=8-12-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9idGY&psc=1 Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted November 18, 2024 Author Share Posted November 18, 2024 Thanks for the suggestions Greg. Yes I was planning to replace the larger hose since the grommet came apart at the valve cover and now it's just setting there. But I didn't know about the common carbon build-up in the smaller one, I'll see if I can carefully remove it and clean it out. Or I might just replace it along with the other since it's only $15 at Napa. I am a little afraid to try and replace the grommet there at this point since it may fall apart like the front one when I try to pull it out, and having just put on the new valve cover I'd hate to have to do it over again if half of the grommet fell inside. Here's where hindsight comes in, should have replaced that when the cover was already off! I'm pretty handy with my soldering iron so I might skip the de-pin plan, but I'll give it some thought! There's a lot of other lines I'd like to replace, the plastic ones are so brittle that they tend to break if you even look strongly at them. But several of them seem to disappear into the obis, or through the firewall, and I don't know what it would take to fish new ones in, and then I don't even know if these molded lines are even available, so I am holding off on that project. GM Link to comment Share on other sites More sharing options...
schardein Posted November 18, 2024 Share Posted November 18, 2024 I meant to mention something about that larger hose. That is where fresh air enters the engine. It is filtered (clean) air from the air cleaner box. Rather than replace the hose, you could put a rubber grommet in the hole in the valve cover and use a regular filtered breather, similar to the one here: https://www.amazon.com/Moroso-68813-Valve-Cover-Breather/dp/B000COO04Q/ref=sr_1_20?dib=eyJ2IjoiMSJ9.-KT67FQuWZXFt3jiLhwuU1EMQJ5i9DVNYDj8av5dds5gcv66t7cIxgTBtaAj1jo3SGVSTOzLXyeNdUNhay0AxcBJ7C1PokbgsltLl6k7ih2zwvIJdBOvYiL9Srzm5hWTtAR58bWZedQmvtvqvQUjVMsl3vblBFlEAA1LimKkmCcS7KmTdGKXMyS1OGdTIdoQCcdTDSbgIdGb0e026KRUaiSaOEayX9ppcxwOzNu2-mw.yedWFLeHlP2ZN4Txy9R4p39xrdwYQcT93rxnCOm0LP8&dib_tag=se&keywords=VALVE+COVER+BREATHER&qid=1731937903&sr=8-20 This is just one example, there are a bunch of different designs that do the same thing. You would just need to match the grommet to the valve cover and the breather to the grommet to make sure it all worked together. And make sure it fits under the hood. And cap off the nipple on the air cleaner box. Personally, I would prefer to keep the factory setup if the parts are still available. Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted November 19, 2024 Author Share Posted November 19, 2024 12 hours ago, schardein said: I meant to mention something about that larger hose. That is where fresh air enters the engine. It is filtered (clean) air from the air cleaner box. Rather than replace the hose, you could put a rubber grommet in the hole in the valve cover and use a regular filtered breather, similar to the one here: https://www.amazon.com/Moroso-68813-Valve-Cover-Breather/dp/B000COO04Q/ref=sr_1_20?dib=eyJ2IjoiMSJ9.-KT67FQuWZXFt3jiLhwuU1EMQJ5i9DVNYDj8av5dds5gcv66t7cIxgTBtaAj1jo3SGVSTOzLXyeNdUNhay0AxcBJ7C1PokbgsltLl6k7ih2zwvIJdBOvYiL9Srzm5hWTtAR58bWZedQmvtvqvQUjVMsl3vblBFlEAA1LimKkmCcS7KmTdGKXMyS1OGdTIdoQCcdTDSbgIdGb0e026KRUaiSaOEayX9ppcxwOzNu2-mw.yedWFLeHlP2ZN4Txy9R4p39xrdwYQcT93rxnCOm0LP8&dib_tag=se&keywords=VALVE+COVER+BREATHER&qid=1731937903&sr=8-20 This is just one example, there are a bunch of different designs that do the same thing. You would just need to match the grommet to the valve cover and the breather to the grommet to make sure it all worked together. And make sure it fits under the hood. And cap off the nipple on the air cleaner box. Personally, I would prefer to keep the factory setup if the parts are still available. Good input. If the OEM wasn't available good to know there is a convenient backup plan. Surprisingly, the full assembly appears to be available in 2 piece, where I would only need the end half.. https://www.napaonline.com/en/search?text=vacuum harness&referer=v2, and it is actually cheaper that the example aftermarket you noted, go figure! Link to comment Share on other sites More sharing options...
AZJeff Posted November 20, 2024 Share Posted November 20, 2024 Virtually any of the hard plastic vacuum/vent lines on a 30 yr old MJ are going to be super brittle, and they will crack if you even look at them wrong.😁 if you want to fix this once and for all, I recommend replacing all the hard lines with appropriate sized rubber or silicone tubing. Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted November 23, 2024 Author Share Posted November 23, 2024 Well it seems the more I "fix" the more problems I get. At the beginning of this thread the problem was the disconnected hose for the MAP sensor that caused the truck to run VERY rough. Once this was reconnected it ran normal. Although the original task of replacing the valve cover gasket damaged hose connecting at the front of the valve cover I ordered the new assembly from Napa I linked earlier. This assembly came with all new hoses to the left (the "New" side in picture 1). 1 of these was the new hose to the valve cover. 2 of these were short loop backs, and the 4th was from the assembly routed below the large corrugated hose from the air cleaner box to something just to the other side under the hose (pic 2). The kit also included an additional new hose which I installed also. For access I removed the large hose from the air cleaner, and also disconnected one electrical connection. Now with all of this in place, the truck once again runs rough. Not nearly as rough as the original failure caused by the MAP sensor being disconnected, but still rough and it ran smoothly before this (*once, before this new assembly was put in but after the MAP sensor issue was resolved, when I stopped somewhere the idle was higher than usual but returned to normal when I restarted). The new connections match the old ones, the MAP sensor is still connected (I checked again), so what happened? The only other thing I did was attempt to remove the small hose to the back of the valve cover to try to clean it, but it was not willing to come loose at the engine side so the original is still there same as it was before. Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted November 23, 2024 Author Share Posted November 23, 2024 Oh I also put in a new cap where you add oil to replace the old one that was very loose because the gasket was worn out. Link to comment Share on other sites More sharing options...
Ωhm Posted November 23, 2024 Share Posted November 23, 2024 Make sure that additional hose (Fuel Pressure Regulator (FPR)) is connected at the intake manifold. Can't tell by photo. Idle may get better with time (RELEARN) after all your fixes. May need time here (drive cycles) to see if things improve. Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted November 23, 2024 Author Share Posted November 23, 2024 7 minutes ago, Ωhm said: Make sure that additional hose (Fuel Pressure Regulator (FPR)) is connected at the intake manifold. Can't tell by photo. Idle may get better with time (RELEARN) after all your fixes. May need time here (drive cycles) to see if things improve. Thanks, I have checked and all the hoses are connected where they were originally. I think this pic shows the other end of the one you mentioned correct? Jeep is running rough enough that I don't feel like is should really be driven, I don't want to get stranded along the road! Can you guess at all how much relearning time might be needed? Am I right to assume it could relearn just setting in my garage running rather than actual driving? Link to comment Share on other sites More sharing options...
Ωhm Posted November 23, 2024 Share Posted November 23, 2024 11 minutes ago, AnotherOldJeepGuy said: I think this pic shows the other end of the one you mentioned correct? Other photo showed elbow at manifold connection. Looks correct in latest photo. 16 minutes ago, AnotherOldJeepGuy said: Can you guess at all how much relearning time might be needed? Taken from RELEARN procedure: The following general procedures are to be used if drivability problems are encountered after power loss or battery has been disconnected. These procedures may provide an aid in eliminating these problems. 88 FSM Computer Relearn Procedures.pdf Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted November 23, 2024 Author Share Posted November 23, 2024 Ah got it. Doesn't look like letting it run in the garage will cut it . I didn't have the battery disconnected but I get that a reset could still possibly be useful. I'll have to drive it to go through the reset, still not crazy about doing that but short of other ideas I guess I will risk it. Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted November 23, 2024 Author Share Posted November 23, 2024 It's halftime for the game I am watching so I just disconnected the battery. I'll hook it back up after the game. Per the reset info, this should load default settings. If the settings being no longer good with the new hoses is the problem, maybe defaults are a better place to start. Will post back if that helped. Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted November 24, 2024 Author Share Posted November 24, 2024 Football game's over, we won! Now going for a second win... Reconnected the battery and started up running normal! I'm not going into full celebration mod just yet because it did hiccup about 3 times, but overall it ran normal. I am cautiously optimistic the ECU reset did it and the RELEARN advice was what I needed. Once again the expertise of this group comes to the rescue! Thanks again. Link to comment Share on other sites More sharing options...
pizzaman09 Posted November 24, 2024 Share Posted November 24, 2024 For all people chasing poor running, I always recommend checking the intake manifold exhaust header nut tightness. They have a habit of backing out and simultaneously causing intake and exhaust leaks. Torque them down and see if any are loose. Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted November 24, 2024 Author Share Posted November 24, 2024 3 hours ago, pizzaman09 said: For all people chasing poor running, I always recommend checking the intake manifold exhaust header nut tightness. They have a habit of backing out and simultaneously causing intake and exhaust leaks. Torque them down and see if any are loose. I have driven a couple more times since my battery disconnect reset and so far knock on wood still running normal. But the overall loudness of the running engine has gotten slowly louder. I have been assuming this was my 25 year old muffler but the next time I am in there I'll try to see if any are loose. Happen to know what torque these should get assuming I find any loose? Link to comment Share on other sites More sharing options...
pizzaman09 Posted November 24, 2024 Share Posted November 24, 2024 15 minutes ago, AnotherOldJeepGuy said: I have driven a couple more times since my battery disconnect reset and so far knock on wood still running normal. But the overall loudness of the running engine has gotten slowly louder. I have been assuming this was my 25 year old muffler but the next time I am in there I'll try to see if any are loose. Happen to know what torque these should get assuming I find any loose? I don't really know, I made them as tight as I could mange as they are all hard to get to and fairly awkward to get wrench on. They are 3/8-16 thread. Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted November 24, 2024 Author Share Posted November 24, 2024 Gotcha. Well if they are hard to get to its gonna have to wait a couple months until I am free of my Darth Vader glove... ! I'll keep it on the to do list though! Link to comment Share on other sites More sharing options...
Ωhm Posted November 24, 2024 Share Posted November 24, 2024 OUCH! Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted November 24, 2024 Author Share Posted November 24, 2024 Thanks. Not bad really, just a sprain, more annoying than anything else. But doc said if I want it to heal and stop hurting every time I open my truck door I have to wear this thing for 2 months! I managed to do the hoses "short handed" but some things are gonna have to wait Link to comment Share on other sites More sharing options...
