that88jeepMJ Posted October 24, 2024 Share Posted October 24, 2024 How much lift do i need to put 37’s on my 1988 Comanche? I am willing to cut the fenders if i have to. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted October 24, 2024 Share Posted October 24, 2024 You might find this helpful. Link to comment Share on other sites More sharing options...
robfg67 Posted October 26, 2024 Share Posted October 26, 2024 Is jpnjim MJ from the 2011 thread on 37's original factory color yellow? If so, could it be one of the Pennzoil Giveaway MJ's? Link to comment Share on other sites More sharing options...
89 MJ Posted October 26, 2024 Share Posted October 26, 2024 25 minutes ago, robfg67 said: Is jpnjim MJ from the 2011 thread on 37's original factory color yellow? If so, could it be one of the Pennzoil Giveaway MJ's? @jpnjake would probably know Link to comment Share on other sites More sharing options...
jpnjake Posted October 27, 2024 Share Posted October 27, 2024 5 hours ago, robfg67 said: Is jpnjim MJ from the 2011 thread on 37's original factory color yellow? If so, could it be one of the Pennzoil Giveaway MJ's? 5 hours ago, 89 MJ said: @jpnjake would probably know Thanks Carter! That truck was originally gray metallic from the factory, someone painted “ an inch of the thickest yellow rustoleum tractor paint” that my dad has ever seen on it Even 20 years later the yellow paint come through a little bit through the new maroon ^now after I went a little heavy with the pressure washer ^ 20 ish years ago when it was converted from yellow (yes that’s me in the bed) Link to comment Share on other sites More sharing options...
