Torq_Shep Posted September 7, 2024 Share Posted September 7, 2024 I was having issues with my driver's door latch and I pulled it out and ultrasonic cleaned it. I want to put it back in but I am curious what lubricant I should re-apply to it? Any suggestions? Link to comment Share on other sites More sharing options...
89 MJ Posted September 7, 2024 Share Posted September 7, 2024 I’d think white lithium grease would be your best bet. Link to comment Share on other sites More sharing options...
Spinnakerblue89 Posted September 8, 2024 Share Posted September 8, 2024 4 hours ago, 89 MJ said: I’d think white lithium grease would be your best bet. Everyone that I know who has ever been a mechanic or body guy has insisted that white lithium grease is the way to go. +1 WLG Anecdotally, it fixed the squeaky doors on both my ZJ and my Ranger. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted September 8, 2024 Share Posted September 8, 2024 I used lithium grease on the first set I repaired. Use “green grease” which is a marine grease on the second set. Both worked well but the green grease lasted longer Link to comment Share on other sites More sharing options...
Torq_Shep Posted September 9, 2024 Author Share Posted September 9, 2024 I will use lithium grease. I actually bought it before I saw @ghetdjc320's comment but I think the regular stuff will be fine. I am pulling it out of the door in the next few years again anyway. Link to comment Share on other sites More sharing options...
Spinnakerblue89 Posted September 9, 2024 Share Posted September 9, 2024 On 9/8/2024 at 5:48 AM, ghetdjc320 said: I used lithium grease on the first set I repaired. Use “green grease” which is a marine grease on the second set. Both worked well but the green grease lasted longer Is that similar to the red grease usually used in industrial applications? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted September 10, 2024 Share Posted September 10, 2024 35 minutes ago, Spinnakerblue89 said: Is that similar to the red grease usually used in industrial applications? It may be. It doesn’t wash out and is quite sticky. Doesn’t melt easily either. When I was rebuilding hvac control panels, that was one of the greases I was using. Link to comment Share on other sites More sharing options...
75sv1 Posted September 10, 2024 Share Posted September 10, 2024 I use the green grease for stuff. I think it has some 'corn' grease in it. I used 'corn' grease for an old John Deere mower rear axle. It is what JD specs or sold. Corn grease is suppose to fold itself back into the gears. I also use the Werth spray for some hinges and other stuff. It is a dry film lubricant. Link to comment Share on other sites More sharing options...
