1JTMR65T1HT089244
Bent
VIN: 1JTMR65T1HT089244
1987 4X4 Laredo, Long Bed 4.0, AW4, NP231, HP D-30, OE D-44; open/open. Functioning load sensing valve. OE Turbine rims & hubcaps w/235s (5). Factory door mount mirrors.
Build date sticker lost due to respray by a previous owner.
Factory skid plate option. Resprayed 1988 Coffee; appears to have been Black from the factory.. Tan interior; Cloth/vinyl bucket seats w/ adj headrests; center console shift. Factory fog lights. AC. Electrical system unmolested.
Front leveling springs by previous owner.
Purchased 1995 from San Diego area. Current mileage: (06/2024) 143,400 original miles.
Still on the road as daily driver, Gets used as a truck at home and for USFS Adopt-A-Trail volunteer trail cleanup & maintenance.
Appears Stock, but has enhancements for off road capability; Stinky Fab crossmember/TC skid, engine and trans mounts. Sway bar disconnects; extended stainless steel brake lines; YJ E-brake cables; adjustable RE Super Flex upper and lower control arms; 1995 booster & MC upgrade. 4 hole injector upgrade. Optima Yellow Top sitting in modified Dirtbound Offroad battery tray w/ self fabed hold-down. CSF 3-row brass & copper radiator. Stinky Fab AW4 transmission skid; Bilstein 5100 series shocks.
Located in Redlands, CA (SoCal)
Owner: Tim B. /self
Same username on NAXJA
Edited by Bent
Pics & forgot to include some specs.
On 6/28/2024 at 5:36 PM, Eagle_SX4 said:
Awesome truck. How is that radiator? I am thinking about getting one.
The Three core radiator requires plenty of pressure to pull air through effectively. Currently have an aftermarket auxiliary fan that I need to replace with an OEM unit. Thinking about doing the Grand Cherokee fan clutch, if there is room. Having the aftermarket auxiliary fan versus the original equipment makes a noticeable difference.
On 6/30/2024 at 1:05 PM, fiatslug87 said:
It's not a factory Big Ton, 8th digit is a T which means Laredo, Std. Payload. A "U" is Laredo, Metric Ton.
Years ago I ran the VIN, and came up with 2,200 lb payload. I know it easily handles a 2,400 lb pallets of pavers through intersections and down the freeway without bottoming out. Multiple times, properly loaded. 😅
I know my way around the MJ fairly well. But when it comes to accurate information this is where I come. I certainly appreciate the input!
BODY:JP62
BUILD: 01/21/87
SELLING DEALER: ORANGE COAST CHRYSLER DODGE, JEEP
COSTA MESA, CA
*W7   -YY DESCRIPTION NOT AVAILABLE ADA LIGHT GROUP
ADL SKID PLATE GROUP AGL OPEN AHY
APA MONOTONE PAINT AWE   AWH POWER EQUIPMENT GROUP
BCQ MAINTENANCE FREE BATTERY CAC LOW BACK BUCKET SEATS CGW
CKA CARPETS - FLOOR AND CARGO AREA CLE FLOOR MATS CUF FULL LENGTH FLOOR CONSOLE
DGQ 4-SPD AUTOMATIC TRANSMISSION DMR 3.55 REAR AXLE RATIO ERB 4.0L I6 MPI ENGINE
GAC TINTED GLASS WINDOWS GEC FRONT LEFT SIDE SLIDING WINDOW GFD REAR SLIDING WINDOW
GPB BLIND SPOT,PWR,FOLD PURSUIT MRRS HAA AIR CONDITIONING HCC DO NOT USE - SEE HCA
JAY DO NOT USE - SEE JP, KA CLASSES JFH TACHOMETER JGB
JHA VAR INTERMITTENT WINDSHIELD WIPERS JJA CIGAR LIGHTER K60 STRIPE/BADGE/MOLDING
LBB COURTESY LAMPS LDA UNDERHOOD LAMP LMA HALOGEN HEADLAMPS
LNJ FRONT FOG LAMPS LPE CARGO LAMP MBF BRIGHT REAR BUMPER
MCA   MCB   MDA FRONT LICENSE PLATE BRACKET
MFD BRIGHT GRILLE NAE CALIFORNIA EMISSIONS NFA 23 GALLON FUEL TANK
NHB AUXILIARY TRANSMISSION OIL COOLER NHM SPEED CONTROL NMB STANDARD DUTY ENGINE COOLING
PX6
Classic Black
QX6
Classic Black
RAF OPEN
SBA POWER STEERING SCE STEERING WHEEL SUA TILT STEERING COLUMN
TBB FULL SIZE SPARE TIRE TBL INSIDE MOUNTED SPARE TIRE WJN 15 ALUMINUM WHEELS
XEA TOW HOOKS 3LZ DESCRIPTION NOT AVAILABLE
COSTA MESA, CA
Well that helps to explain the lack of rust. Doesn't appear the rear slider is stock. It "may" be OEM, but not original equip.
Thanks much. - Tim
Thanks much. - Tim
4 pane window will be aftermarket.  factory ones were 3 pane. :L:
I went through and edited out the common mistakes in the codes
