Bent
    Redlands, SoCal
986 profile views
Bent's Achievements
  1. Bent
    1JTMR65T1HT089244
    Well that helps to explain the lack of rust. Doesn't appear the rear slider is stock. It "may" be OEM, but not original equip. Thanks much. - Tim
  2. Bent
    1JTMR65T1HT089244
    Years ago I ran the VIN, and came up with 2,200 lb payload. I know it easily handles a 2,400 lb pallets of pavers through intersections and down the freeway without bottoming out. Multiple times, properly loaded. 😅 I know my way around the MJ fairly well. But when it comes to accurate information this is where I come. I certainly appreciate the input!
  3. Bent
    1JTMR65T1HT089244
    The Three core radiator requires plenty of pressure to pull air through effectively. Currently have an aftermarket auxiliary fan that I need to replace with an OEM unit. Thinking about doing the Grand Cherokee fan clutch, if there is room. Having the aftermarket auxiliary fan versus the original equipment makes a noticeable difference.
  4. Bent
    1JTMR65T1HT089244
    VIN: 1JTMR65T1HT089244 1987 4X4 Laredo, Long Bed 4.0, AW4, NP231, HP D-30, OE D-44; open/open. Functioning load sensing valve. OE Turbine rims & hubcaps w/235s (5). Factory door mount mirrors. Build date sticker lost due to respray by a previous owner. Factory skid plate option. Resprayed 1988 Coffee; appears to have been Black from the factory.. Tan interior; Cloth/vinyl bucket seats w/ adj headrests; center console shift. Factory fog lights. AC. Electrical system unmolested. Front leveling springs by previous owner. Purchased 1995 from San Diego area. Current mileage: (06/2024) 143,400 original miles. Still on the road as daily driver, Gets used as a truck at home and for USFS Adopt-A-Trail volunteer trail cleanup & maintenance. Appears Stock, but has enhancements for off road capability; Stinky Fab crossmember/TC skid, engine and trans mounts. Sway bar disconnects; extended stainless steel brake lines; YJ E-brake cables; adjustable RE Super Flex upper and lower control arms; 1995 booster & MC upgrade. 4 hole injector upgrade. Optima Yellow Top sitting in modified Dirtbound Offroad battery tray w/ self fabed hold-down. CSF 3-row brass & copper radiator. Stinky Fab AW4 transmission skid; Bilstein 5100 series shocks. Located in Redlands, CA (SoCal) Owner: Tim B. /self Same username on NAXJA
  5. If you are within driving distance of Cajon Pass in CA. and would be interested in helping with USFS Adopt-A-Trail trail cleanup, please contact me. TEXT 9o9-six 33- 86 zero five.
    Or Visit: NAXJA SoCal Chapter AAT
  6. https://www.etsy.com...hop_home_feat_1 This links to his store on Etsy.
  7. And I'm in Redlands, the other side of San Timoteo from you. http://comancheclub.com/forums/viewtopic.php?p=6658#p6658
  8. 1987 4X4 Laredo Metric Tonne, Long Bed 4.0, AW4, NP231, D-44 122,000 miles
