jamespwsullivan Posted June 18, 2024 Share Posted June 18, 2024 So it has been several years since I took the interior out of my MJ and I want to make sure that I put it back in the most efficient and effective order. I have new headliner and carpet plus I think all of the interior trim panels are in good shape and ready to install. The upper A pillar trims (not the lower kick panels) seem to test fit just fine but it looks like the lower attachment screw-right around the middle of the dashboard up and down-needs to be installed with the dash out. Is that true? Does the headliner need to be installed first-before the A and B pillar trims-in order to be the easiest install? Thanks in advance for any tips and suggestions. Link to comment Share on other sites More sharing options...
Spinnakerblue89 Posted June 18, 2024 Share Posted June 18, 2024 I haven't yet put my headliner in, but by the looks of it, it's best to put that in before the trim if even just for an easier install. In fact, I'm pretty sure very headliner I've dealt with had required the trim to be attached after the fact. Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 18, 2024 Share Posted June 18, 2024 Headliner first. Then the rest. You might be able to get away with sliding the headliner around with the upper portion of the A and B pillar panels loose. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted June 18, 2024 Share Posted June 18, 2024 Install the lower panels from the front kick panels along the floor to the back first before you put the B pillar panels in. The B pillar panels sit on top of and outside of the lower panels. Link to comment Share on other sites More sharing options...
speeding_infraction Posted June 18, 2024 Share Posted June 18, 2024 I was able to put the a pillar trim in without removing the dash, just be very gentle as they are a bit fragile. Link to comment Share on other sites More sharing options...
jamespwsullivan Posted June 19, 2024 Author Share Posted June 19, 2024 3 hours ago, TurboedMJ said: I was able to put the a pillar trim in without removing the dash, just be very gentle as they are a bit fragile. Yeah I test fitted the driver's side without damage but it looks like there is a screw that holds the A pillar trim to the body and it lines right up with the center line of the dash. That's why I think the dash has to be backed out. There's only one or maybe two other anchor points for that A pillar trim as far as I can see. Link to comment Share on other sites More sharing options...
jamespwsullivan Posted June 19, 2024 Author Share Posted June 19, 2024 6 hours ago, Eagle_SX4 said: Install the lower panels from the front kick panels along the floor to the back first before you put the B pillar panels in. The B pillar panels sit on top of and outside of the lower panels. Great advice. Thanks! I realized I hadn't identified the trim that goes under the door in my pile of plastic so I took a better look and found both pieces. Now what you said make perfect sense. Link to comment Share on other sites More sharing options...
jamespwsullivan Posted June 19, 2024 Author Share Posted June 19, 2024 20 hours ago, eaglescout526 said: Headliner first. Then the rest. You might be able to get away with sliding the headliner around with the upper portion of the A and B pillar panels loose. That's what I was figuring. Since the rest of the cab is bare I won't need to worry about the tops of the pillar panels. Thanks. Link to comment Share on other sites More sharing options...
pizzaman09 Posted June 19, 2024 Share Posted June 19, 2024 20 hours ago, eaglescout526 said: Headliner first. Then the rest. You might be able to get away with sliding the headliner around with the upper portion of the A and B pillar panels loose. I've done the headliner with the A and B pillars just loose, it's doable, but it isn't fun. Two people and some patience it will turn out. It would be way easier to do with the A and B pillars removed. Link to comment Share on other sites More sharing options...
pizzaman09 Posted June 19, 2024 Share Posted June 19, 2024 Another tip, if you are putting sound deadening material like dynamat on the roof, avoid the center because that extra thickness near the center will force the headliner to sit down and a bit farther forward than it should. I had covered my whole roof in it and it did make it more challenging to fit the headliner. Dynamat doesn't need to be placed everywhere anyway to reduce vibration in panels. Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 19, 2024 Share Posted June 19, 2024 9 minutes ago, pizzaman09 said: I've done the headliner with the A and B pillars just loose, it's doable, but it isn't fun. Two people and some patience it will turn out. It would be way easier to do with the A and B pillars removed. That’s assuring. I have to take my headliner out here soon and reglue my tweed back to the headliner. I hate taking the interior apart as basically everything is held in place by that damn back panel under the window. Thing is so fragile that it makes the thought of taking the interior apart a nightmare. Link to comment Share on other sites More sharing options...
