gogmorgo Posted April 9, 2024 Share Posted April 9, 2024 Someone who is currently 52 didn’t have LED headlights to contend with when going through driving school 😅 Anyone getting spooked by someone passing them isn’t paying enough attention to what’s in their mirrors, and it’s on them for getting spooked. If I’m doing 10 over and you’ve been sitting behind me for a couple minutes and I signal and move over to let you by when a passing lane appears, you don’t need to flash your lights at me before you go by. If you’re passing me in the oncoming lane on a 2-lane, I’ll see your turn signal before you pull out. Lighting up my mirrors and making me see spots is just a straight up dick move. But going back to my original question, when using flash to pass in an MJ, is that just when you pull on the multifunction stalk part way but not far enough to lock in the high beams? Pretty sure both my MJs and my ZJ do that but I didn’t think it was a deliberate feature that required additional parts. My 3/4 ton has the stalk you push forward to lock in high beams, so I’m constantly hitting the flash-to-pass because I’m so used to the MJ. The Ladas are… different. Definitely don’t have flash-to-pass. There’s a second stalk behind the turn signal stalk that you flip up and down for low and high beam. Definitely haven’t smacked that by mistake while signaling. Nope, no way. Link to comment Share on other sites More sharing options...
75sv1 Posted April 9, 2024 Share Posted April 9, 2024 I do use low beams to signal to Semis, that they can pull out. That I am clear of them. I don't like hi beams. As to the temp and Direction, some of the XJs have that in an overhead. I installed one on my "98 XJ. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 31 Share Posted January 31 I want to add to this. I am about to add the switch to both my Jeeps and I went hunting for the TSB. The TSB issues that for the early 89 years, the flash to pass only triggers the low beam instead of the high. The TSB tells you to switch the green wire and tan wire in the connector around and it will fix the problem which it does. It is exactly what I ran into on my MJ and now the high beams come on instead of the low beams when using the flash to pass feature. If anyone does add the switch to their pre-Chrysler XJ or MJ, the terminal space is open in the connector, 56 series female terminal and whatever you want to plug into the fuse block. And switch the two wires around to get it to work properly. I mean why not add this switch? Same exact switch other than moving two wires and adding a power wire to the circuit. Link to comment Share on other sites More sharing options...
