Renix Mopar ECU
I just pulled an ECU out of a 90 Cherokee (doing the upgrade for my 88 MJ) and noticed it doesn’t have the factory sticker on it but one that says it’s a Mopar rebuild from 2002. Is there anything special with these (I heard somewhere that there was a Mopar upgraded ECU at one point?) or is it the same specs as an OEM computer? Thanks!
4 hours ago, cruiser54 said:
If that.
If you can find the OEM number on the unit somehow, we could determine the year.
The performance ECU had a P as a prefix FWIW.
I looked over the case and couldn’t find any other part numbers besides the one sticker on it. Maybe I could find it if I took the case apart? It was a struggle to get it installed so I don’t really want to take it out again for a while haha
