Cap / Topper - Need More Information
Hi!
Once upon a time I saved this image of a Comanche with what I think I remember to be a "factory top" for the bed (see attached).
Does anyone have any information on these toppers? Do they appear for sale ever?
I really like the lines of it - enough to maybe try 3d printing one.
Does anyone have more pictures of these tops?
On 2/25/2024 at 12:15 AM, Root Moose said:
Hi!
3D printing? Where do you work to have access to a printer that big? 😅
I have a red 1988 Ford Ranger that came with a topper when I bought it a few years ago. It's actually an S-10 topper according to the PO, and it's just slightly too long for the Ranger, but is compensated for with padding.
I have no use for a topper, I bought the truck to haul things with such as furniture and frequently the topper gets in the way. However, I haven't removed it yet because the PO installed a CB radio antenna on it and I haven't given any thought yet on where to put it. When I do get around to it, I'll see if it fits the Comanche.
Unless measurements may be enough?
I did a reverse image search with google and found a thread about portal axles.
It says the truck was owned by a member named JohnX, you could message and see if he know what type of topper it is.
I also like the lines of it, and JohnX's Comanche with volvo portal axles.
You can also do it in sections.
There Is a guy I have seen on youtube that you can buy models to make a fast back top for a miata.  print in sections and then fiberglass over it.
Not strictly 3D printing but easier than make molds.
Yes, exactly.
I considered doing it that way. I have a Prusa Original XL that has a print volume of about 14" x 14" x 14" but I think I'd rather do it one piece. It's fiddly doing it in parts and nowadays building your own printer is not that big a deal compared to what it once was. Plenty of resources out there.
On 3/15/2024 at 4:13 PM, Root Moose said:
Yes, exactly.
You are right, CNC has never had easier barriers to entry than now, but as someone who has used 3D printing professionally, trying to print a single piece that large scares the crap out of me.
Printing in sections will require more work on the back end, but I can't imagine my reaction if i had a print of that volume that had a failure near the end of its print.
