Pete M Posted December 4, 2023 Share Posted December 4, 2023 so both boxes I have on hand leak quite a bit out the input. how hard is that to change out? trying to save some money on the project. Link to comment Share on other sites More sharing options...
gogmorgo Posted December 4, 2023 Share Posted December 4, 2023 I would just rebuild the whole thing, the seal kits are pretty cheap, you can get kits with bearings as well. Lots of how-tos online for rebuilding a Saginaw steering gearbox. They’re not too bad to do. There’s just a few fiddly bits. Don’t lose the balls out of it, count them when they come out and as they go back in. If it’s missing one it’s going to cause problems. If you can get a plastic tray or something under it to catch them when it comes to that part it’ll help you out. Link to comment Share on other sites More sharing options...
Htchevyii Posted December 5, 2023 Share Posted December 5, 2023 I tried to replace the input seal once before the internet was very useful. I got the preload all screwed up and the box wouldn't return to center on its own. That was an interesting test drive on the freeway. 🙄 Link to comment Share on other sites More sharing options...
cruiser54 Posted December 5, 2023 Share Posted December 5, 2023 I'd go snag a non leaking used ZJ box at the junkyard. Link to comment Share on other sites More sharing options...
75sv1 Posted December 5, 2023 Share Posted December 5, 2023 I've done one or two. I used an Inch-LB dial torque wrench. Some of the instructions go with a mark, then turn 1/2 inch. Also, the shaft may be worn at the seal location. The lock nut should be torqued to 75-ft -lbs. I just put some Loctite on and banged the nut tight. Meaning to make something to tighten the nut and be able to keep the other part in place. Link to comment Share on other sites More sharing options...
GrandBoost98 Posted December 11, 2023 Share Posted December 11, 2023 Ill be diving into this within the next week or so on my YJ. Same box except I added hydro assist. I already replaced the pitman arm seal on my box a couple years ago. Now the input seal is shot. Thought about getting an upgraded box but quickly changed my mind after seeing the price tag. After looking at a couple other threads, it doesnt seem too bad to replace Link to comment Share on other sites More sharing options...
