I've done a 2wd to 4wd conversion on my short wheel base 1988 MJ.
I'm confident the front driveshaft is the same as the XJ. What rear driveshaft do I use with an AW4/NP231J?
Is there a factory driveshaft
Or do I have to have one made?
yup, those are the choices.  none are especially awesome.  :(
-used MJ shafts are getting hard to find and most every possible drivetrain has a different length.
-custom shafts from Dennys or Adams aren't especially cheap, but they are much stronger than factory.  maybe you have a shop locally to you that can make one?
-2wd shafts are weird and have a rubber isolator on the axle end.  it's possible to shorten them (I did), but you have to cut the t-case end and then hope the rubber is still good enough after 35 years.
the link in my signature has a thread with all the various MJ driveshaft lengths.  :L:
I had a driveshaft shortened for a Ford when we manual swapped it.  It was a great option, just went to the local heavy duty truck shop which built drive shafts.  They also fitted it with new Spicer u joints.  Price was way less than any other option and I'd argue the quality better.
