Big_Mark Posted June 12, 2024 Share Posted June 12, 2024 Naw I didn't roll over THERE lol... I did roll other places though, that's how I learned the limits of that Old Jeep! P.S. that was me in 2009 Link to comment Share on other sites More sharing options...
Drahcir495 Posted June 13, 2024 Author Share Posted June 13, 2024 Now that I have everything cleaned up and all the bearings and seals pulled - it’s time to start rebuilding. I now press on the inner pinion bearing and slinger on the new pinion -> Before pressing the new gear onto the new carrier I brake cleaned all the holes in the ring gear and ring gear bolts. Now on the press to seat the ring gear on. Very important to add red locktite to the bolts before torquing them to 60 foot pounds -> Now ready for the set up process-> The old carrier has shims behind the carrier bearings for proper backlash. The bearings need to be removed to get them out. They need to be kept together (left and right). This just gives you a starting point for the setup and not going at it from scratch. We have a special bearing puller for this, but on occasion they break when removing even with using this. We just use a Dremel to cut the bearings off if that happens -> The bearings off and the shims out (I use bailing wire to keep the right side separated -> We use slip fit bearings for setup. They will be taken off and on a lot during the set up, so we don’t want to damage the flight bearings during initial set up. After a bit of +/- shims we get an acceptable pattern -> We also have a slip fit race (bearing cup) to help getting the pinion depth correct. Now it’s on to setting up pinion preload. As I said earlier, this axle does not use a crush sleeve. It uses pinion preload shims to get the correct (15 inch pounds we set ours at) preload. After a slow process (we try not to use new shim kits because they are $$$) using unused shims until we get that magic number. When we are ready for the final pinion set you first need to drive in the inner flight bearing cup. Make sure all the shims behind the race do not fall out when doing this. Because of this inner baffle -> the pinion shims need to be put in before the bearing and pinion seal are installed. I use a tiny bit of grease to keep the shims together-> Then I place the shim pack inside on the baffle-> Pop the outer pinion bearing in and the oil slinger on top-> and install the pinion seal * don’t forget to oil the seal* -> TBC Link to comment Share on other sites More sharing options...
Drahcir495 Posted June 13, 2024 Author Share Posted June 13, 2024 3 hours ago, Big_Mark said: Naw I didn't roll over THERE lol... I did roll other places though, that's how I learned the limits of that Old Jeep! P.S. that was me in 2009 😁 I can't imagine a roll over! Glad you weren’t hurt or it stopped you from continuing to wheel. Looks like a lot of fun though. Link to comment Share on other sites More sharing options...
Big_Mark Posted June 13, 2024 Share Posted June 13, 2024 My Cj8 was a daily driver / weekend wheeler for about 10 years, then I got tired of wheeling Sat, running to Shucks (now O'Rielly's) on Sundays to fix the broke stuff so I can get to work on Monday so little by little it turned into the thing it was. Most mods were designed to run trails a Reiter Trails (aka Reiter Pit) in Goldbar WA. Dana 60s f/r Detroit locker in front, spool rear, 6:17:1, Blueprinted and balance 5.0 EFI, T-18, Dana 300 with independent f/r hi low for digging around stuff! BTW rolls were mostly flops, were always at low speeds so no worries there. I do not expect to turn my Manche into a thing like that, but I would like to add a few things! Link to comment Share on other sites More sharing options...
Drahcir495 Posted June 14, 2024 Author Share Posted June 14, 2024 I ran into the same problem with my Cherokee. It would break down all the time and I had no back up car. It eventually got everything new, but by that time I was over it and wanted my reliable MJ back. I will have the Scrambler as a weekend toy. I don’t plan on any hard wheeling though. Until the CJ8 is up and running I can’t risk breaking down. Link to comment Share on other sites More sharing options...
Drahcir495 Posted June 20, 2024 Author Share Posted June 20, 2024 Now that the carrier is set up, I can take care of the spindle bearings that fell apart. Here is what I started with -> All the roller bearings fell out of both sides. First step was to pull out the bearings-> As soon as that was done I packed the bearings with grease. Putting in the new bearings-> Used an aluminum bearing installation tooll but I know many other things would work -> Once it was flush, I used an impact socket the same size of the bearing to knock it in a little deeper into the spindle. TBC Link to comment Share on other sites More sharing options...
Drahcir495 Posted August 28, 2024 Author Share Posted August 28, 2024 I finally got around to towing the CJ8 up to the new place.Took the 4 hour drive to its new home. I was following the tow truck the last 30 minutes watching the license plate flapping in the wind. It was hanging on by only one bolt. I figured if it hadn’t flow off in the last 3.5 hours, it probably wasn’t going too . In the new spot in the garage-> Link to comment Share on other sites More sharing options...
neohic Posted August 28, 2024 Share Posted August 28, 2024 Looks great in its new habitat! Link to comment Share on other sites More sharing options...
89 MJ Posted August 28, 2024 Share Posted August 28, 2024 What a cool looking rig! I’d love to find a Scrambler someday. Link to comment Share on other sites More sharing options...
JZLAJeep Posted August 28, 2024 Share Posted August 28, 2024 Love it and love the full length soft top. We came across a CJ-8 with full hard top this summer in northern Idaho. Link to comment Share on other sites More sharing options...
Drahcir495 Posted August 29, 2024 Author Share Posted August 29, 2024 New habitat. 89 MJ - I don’t think I could afford a Scrambler at what they are going for these days. JZLAJeep thanks. There was a time when I was looking for one, but would be a challenge to get it off and on. We like to roll topless down here. So cool to see one though Link to comment Share on other sites More sharing options...
