Jeep Parts AZ
eaglescout526
Starting a new thread for the parts I have that are engine and exterior related.
I am trying something new, I have some wires that I do not need that are complete and not cut up. Wires came from a 4.0L engine harness at C104 and C105 and C103. I can add more if there is an interest in just separate wires. All wires are $5 unless otherwise above the pic of the wire itself.
Prices are listed and OBO
Short bed plastic skid plate $70. EDIT!!, Strap has been removed from skid!!
Chiltons Manuals. $20
Aftermarket Dorman HO thermostat housings. $25 each. Got them from AMC before the closed down. I can’t use them, i don't have an HO.
IMG_1480.jpg.aa1c1a9175d380ae71e0c48c1d74fd52.jpgIMG_1481.jpg.52e7e46b145c87de32e3f4152a27c472.jpg
4.0L Coolant Bottle strap, 2 on hand. $10
Black Renix upper and lower metal grill trim. The upper portion is a bit bent and rusted but I couldn’t just let it sit and get crushed. $100 for the set.
DA88E959-C3FF-443E-8955-62C7F7587A02.jpeg.b4271109c7493282b3454649d76b14a5.jpeg.24efb2a6ce1bbca9d8ca5794da88f560.jpeg
Exterior aftermarket plastic door handles. $10 ea. one passenger and two drivers. All are unused except for one driver was used to just get in and out of my truck when it was being painted.
Drivers
EGR Solenoid 8933002298 or 33002298, $20. 3 in stock
Aftermarket Pass side hood hinge, new in package. $25
Drivers side factory bumper step pad $40
IMG_1496.jpg.a64dc64abc4ced592df360782dcc46e0.jpgIMG_1497.jpg.ee7f2425a7db6ba5145fc17bc6091252.jpg
Pass side factory bumper step pad $40
IMG_0972.jpg.fa9fdd10771c90c3a7eef7742e720b8f.jpgIMG_0974.jpg.cb11a29f766c8dc874862d53e2ad3380.jpg
J4006546-these are the clips that keep the power window and door lock switches in the bezel of the door handle. $3 a piece, I think I have 12 of them.
NOS Knock sensor for the 4.0L Renix. I know it looks different than the original sensor but there is an instruction paper in the bag talking about the change and what needs to be done. $70
Sentinel headlamp/headlamp delay module, no screw, out of them, 8956000636. $20
NOS Passenger side folding 2-door XJ and MJ seat frame. $200, free shipping on this.
Wiring section:
Command-trac wire. C104-C100
Selec-trac wire. C104-C100
EGR, C217-C109. $7 cause it still has the connector. I will clean it.
Sync supply wire. C104-C105. $2
Back up lamp switch. C104-C100
Temp sensor for cluster. C104-C100
Up shift lamp. C104-C100
Alt to cluster. C105-C100
Off road lamps
First set, Not pictured but it is a set of two, complete, wiring is a bit butchered but all there. $100
Second set, Bosch lamps, era correct for the 90's XJs but will look just as correct on the MJ. No bulbs and they ground out via the housing. $200obo
Fog lamp clip/mounts $10
Underhood lamp #1 $100. Works!
Underhood lamp #2 $90. Bulb not included unless I can find it. Also works!
Charcoal tilt column housing. $30 Needs some love but in great shape
Brand new, never been used internal slave cylinder for 87-90 Renix 2.5L. I have no need for it, it came with a kit I bought to replace the clutch on Chunk. Comes with the pilot bearing. $30
  • 1 month later...
  • 5 months later...
  • 3 weeks later...
19 minutes ago, robfg67 said:
Do you have the bench seat belts in the color charcoal gray? Not the parts that are attached to the B pillars, but the parts that come through the seat. See pic.
I might! I’ll have to do some digging for ya and get back to ya.
  • 1 month later...
  • 1 month later...
  • 2 months later...
  • 1 month later...
  • 3 weeks later...
