Throttle position sensor
I have a 2.5L engine in my 1987 Comanche. I am trying to adjust the TPS to factory specs according to the TSM. It says that the voltage reading between terminals B and C should be 5v at WOT. That's what I get but it also reads 5v with the throttle closed. It doesn't vary from closed to open. The TSM doesn't give a voltage spec at closed. Does this seem right? When I check between terminals A and B it changes from less than 1v to 4.7v which looks to be correct according to the manual.
The check is done on the signal wire and the sensor ground wire (or chassis ground alternatively), do not probe the 5v supply wire. Ensure the connector is solid on the sensor and that the actuator lever from the throttle is engaging the sensor. If no change in voltage occurs when you rotate the throttle plate, you have a defective TPS. I went through this exact sensor failure on my XJ just yesterday.
B and C should read 5vdc. It's the MAP sensor supply voltage. I don't know why they say a WOT.
I'm going by the directions in the TSM.
What were the symptoms that caused you to suspect the TSP was bad?
One of the symptoms was that the transmission shifts were super late and overdrive would never engage.
Cruise control was inoperative.
Once I hooked up my OBDII code reader, there was a TPS voltage high fault so I proceeded to check it out with a meter since my reader is unable to show me live data off the PCM.
10 hours ago, cruiser54 said:
do it the old fashioned way.
On Renix, the TPS is 2 parts. One side for engine management and one for auto trans. They work opposite and independent of each other.
I have a standard transmission.
Okay. Then you only have the flat 3-wire connector in use?
It's okay if you have a TPS from an auto trans vehicle. You just don't use the square 4-wire pigtail.
But, you must take your readings from the flat 3-wire connector.
