GrandBoost98 Posted November 25, 2024 Author Share Posted November 25, 2024 Finally got the time to drop the tank yesterday. What a PITA doing it by yourself! But I was able to see and remove the chunk of rubber that was stopping the sender from seating all the way. And I happened to have a replacement in the parts pile. Got the tank reinstalled with some new straps. Need to find some nuts to get the plastic shield back on but thats not a big deal. I also gave it an oil change. Didnt really need it but the drain plug was leaking so I figured why not. Noticed the rear pinion seal is leaking a little bit too so Ill get one of those on order. Today I'm going to bring some gas home for it so I can drive it to a gas station and see if it still leaks or not. And I got the battery on a charger because it was stone cold dead when I went to start it. I had an old one on my bench I swapped in to get it moving but hoping I can revive the other one Link to comment Share on other sites More sharing options...
GrandBoost98 Posted November 25, 2024 Author Share Posted November 25, 2024 took 22 gallons and didnt leak! Probably going to drive it to work tomorrow Link to comment Share on other sites More sharing options...
GrandBoost98 Posted November 26, 2024 Author Share Posted November 26, 2024 may have celebrated too early...Took out the trash last night and smelled gas as I walked by the MJ. I was expecting to see a puddle underneath but there wasnt. I crawled under to see the sender gasket isnt leaking, which was the original problem. But now it looks like gas is seeping from what I assume is a tiny pin hole under the rear strap. Not enough to drip, it was just kinda wet. So I didnt take it to work in fear of it busting open on the way in lol Ill take a better look after work before ordering a new tank. Not looking forward to draining 22 gallons The original straps I took out and the new straps I put in didnt have any sort of rubber to go between them and the tank. Is that normal? If so, if I have to get a replacement tank, should I consider putting something between them? Link to comment Share on other sites More sharing options...
89 MJ Posted November 26, 2024 Share Posted November 26, 2024 Well I’m sure that’s annoying. I never put anything between the tank and the straps, but that’s because it makes them rust faster up north. Link to comment Share on other sites More sharing options...
