GrandBoost98s Comanche 2
Both 2.5L & 4.0L use a B+Latch relay, thanks for pointing that out. When you get a chance, can you do some preliminary voltage checks?
Using a voltmeter or 12vdc testlight (preferred) check for Battery_Voltage (B+) on the following pins (use battery_negative terminal for ground):
D1_2:  B+ (Hot during KEY ON/CRANK).
D1_5:  B+ (Hot at all times)
D1_6:  At KEY ON (B+ (Hot for 2-3 seconds)) or CRANKING (B+ (Hot during CRANK)).
With KEY ON, measure for voltage at D2-4. Determine if flipping the KILL SW changes the voltage reading on that pin.
  • Replies 153
Absolutely! I will do that as soon as I get home from work. I appreciate you taking the time to help me with this :beerchug:
Last night I took it easy, was hot and humid. Noticed the tail lights were thrown on with whatever they had laying around. The driver side only had one screw holding it on and the passenger side had three deck screws in it! So I went through my tub of jeep hardware and found some proper screws to install
Using your preferred test light. All of those check out good. And yes, the kill switch made the light go out. I also tested for voltage on D2_4. Key on it has 12.08v and when I turn the kill switch off I get 1.82v
5 minutes ago, Ωhm said:
D1_2, D1_5 & D1_6 testing are all good readings. D2_4 testing shows that we're dealing with the B+Latch Relay. Why? IDK. Let me look for my next question.
For what it's worth, I noticed the shift indicator flash and was able to hear the fuel pump prime when turning the toggle switch back on
Somehow, I think the toggle SW shuts down the ECU. Anyone else got a understanding for the B+Latch Relay circuit. It's a strange circuit.
1 hour ago, Ωhm said:
Determine which Relay is the B+Latch Relay. Check for HOT AT ALL TIMES on PIN_1 (RED). PIN_4 & PIN_5 should have PINK wires. Pink should help with relay ID.
Pin 1 hot key on or off. And the toggle switch made no difference
17 minutes ago, Ωhm said:
Turn KILL SW OFF. Remove B+Latch relay. Jumper wire between PIN_1 and PIN_4. See if engine STARTS and RUNS.
Kill switch off. B+ relay removed and pins 1 and 4 jumped. It started up and ran for a couple mins and I revved it up a few times. Should I run it longer or is that good?
What really surprised me is that doing this "fixed" the two crank start! I was able to start it on the first crank 3 times. So then I removed the jumper wire, reinstalled the relay, turned on the kill switch and it went back to two crank starts
That's good. Proves we don't need the kill switch.
Next question is "will ENGINE START and RUN with KILL SW OFF and B+Latch Relay reinstalled?
1 minute ago, GrandBoost98 said:
No, does not start just cranks
I think having the KILL SW answered my own question and that proved it. Do you have a known good relay? Swap them out, Try START and RUN again. I'm thinking faulty relay, relay (Coil) ON circuit or ECU not controlling B+Latch Relay function.
I have a drawer of used relays and fuses. I tried 3 different relays and they all acted the same. No start with kill switch off. I did notice that I can turn the kill switch off after it starts running and it will continue running
KEY OFF. KILL SW OFF. Remove Relay. Continuity test
between D2_2 and B+Latch Relay PIN_2
between D2_4 and B+Latch Relay PIN_5
between D2_4 and B+Latch Relay PIN_4
Looking for 0_Ωs.
Looking for 0 Ωs.
D2-2 to pin 2 =4.3ohms
D2-4 to pin 5 =1.5ohms
D2-4 to pin 4 =1.5ohms
I'm calling that as circuits are NOT open. Next two tests involve the ECU connector. Looking for continuity. Same conditions KEY OFF. KILL SW OFF.
D2_2 and C200_7
D2_4 and C200_19
If both test good, all wiring test good. Suspect ECU.
@Ωhm
Ugh, I just had that out too lol
Had to rig up an extention. That by itself ohmed out at 1.4ohms
D2-2 c200-7 =4.2ohms
D2-4 c200-19= 1.5 ohms
So you're saying a new ECU would fix all my problems? This would give power from pins 1 to 4 on the B+ relay and I could eliminate the kill switch and related wiring? Which in turn would fix my two crank start as well?
If so, do I need a specific 2.5l ECU or is one from any mj/xj okay?
I'm not saying, I'm hoping.
If B+Latch Relay worked properly (relay jumper test) you should be able to get rid of kill switch.
@eaglescout526  ECU request help here.
