PIKE Posted June 28, 2023 Share Posted June 28, 2023 I think this should be an easy one but wanted to run it past everyone. My 1989 clip broke after 33 years. What do you recommend? Exact replacement or newer? Will the later clips fit my truck? Thanks Link to comment Share on other sites More sharing options...
JeffK Posted June 28, 2023 Share Posted June 28, 2023 The 97+ work perfect, and they're metal. Link to comment Share on other sites More sharing options...
pizzaman09 Posted June 29, 2023 Share Posted June 29, 2023 2 hours ago, JeffK said: The 97+ work perfect, and they're metal. This is intriguing info Link to comment Share on other sites More sharing options...
PIKE Posted June 29, 2023 Author Share Posted June 29, 2023 3 hours ago, JeffK said: The 97+ work perfect, and they're metal. Will it snap in with no hole drilling? Mine that broke was fastened into two holes. White brittle plastic. Surprised it lasted so long actually. Link to comment Share on other sites More sharing options...
Pete M Posted June 29, 2023 Share Posted June 29, 2023 yup, goes right in (though I had to use a pair of pliers to get it into place). Link to comment Share on other sites More sharing options...
schardein Posted June 29, 2023 Share Posted June 29, 2023 7 hours ago, PIKE said: Will it snap in with no hole drilling? Mine that broke was fastened into two holes. White brittle plastic. Surprised it lasted so long actually. Here is a link to an eBay listing with some good info. It’s easier to post this than write it all again. If you live near a self service junkyard, you should be able to find the late model replacement, although you may have to be patient for one to show up in the yard. https://www.ebay.com/itm/234189152380?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=bpFa1QANQb2&sssrc=2051273&ssuid=bpFa1QANQb2&var=&widget_ver=artemis&media=COPY Link to comment Share on other sites More sharing options...
JeffK Posted June 29, 2023 Share Posted June 29, 2023 Easy fix. Some pics. Link to comment Share on other sites More sharing options...
PIKE Posted June 29, 2023 Author Share Posted June 29, 2023 Thank you everyone. Going to order one today. Link to comment Share on other sites More sharing options...
