The86manche Posted May 29, 2023 Posted May 29, 2023 I've got an 86 mj with the 2.8 and I'm swapping intakes. the riser is for a 4bbl, unfortunately I couldn't find a 2bbl one, so I'm just trying to make it work. I have a 1 inch spacer for a 4 to a 2 bbl, my concern is for fuel delivery in the intake depending on positioning of the carb 4bbl riser Carb forward Carb back. My concern is will adequate fuel still get to either the front of back depending on where the Carb is bolted. Or am I overthinking this?
ratrapp Posted May 29, 2023 Posted May 29, 2023 what intake are you using?ive been looking for a 4 barrel intake for my 2.8 to use my sniper kit on.
The86manche Posted May 29, 2023 Author Posted May 29, 2023 It's edelbrocks intake. I wish you good luck they have been discontinued and it's hard to find now
The86manche Posted May 29, 2023 Author Posted May 29, 2023 13 hours ago, Pete M said: is the spacer needed for clearance or something? Less for clearance more for adapting. It's kind of one of the only ones I could find that would work.
cruiser54 Posted May 30, 2023 Posted May 30, 2023 Why don't you sell your manifold to ratrapp and use your old manifold with a Weber?
The86manche Posted May 30, 2023 Author Posted May 30, 2023 2 hours ago, cruiser54 said: Why don't you sell your manifold to ratrapp and use your old manifold with a Weber? I've heard mixed reviews on the webber carb.. plus I honestly don't want to take the manifold back off at this point 😅
cruiser54 Posted May 30, 2023 Posted May 30, 2023 webers are fine. I do understand not wanting to remove that manifold though. What a piss-poor design.
ratrapp Posted May 30, 2023 Posted May 30, 2023 The reason i want to take my weber off is I'm less than happy with it.In its defense i havent had the time to seriously adjust on it and it was definitly better than the gm pos that was on it.
