Wiring pigtail for bulb 37 that plugs into back of bezel (See Pic)
I need the 2-wire pigtail that has the black plastic socket that plugs into the back of the fog or cargo light bezel.
See Pics...
Indeed I do but they are all packed away atm. There are some aftermarket ones that will fit (albeit not as good as oem). Search Amazon for a “74 bulb socket” unless you need oem
Just read the reviews on Amazon and it sounds like it's hit or miss on fit.
I can wait for the OEM one. Let me know-no rush at all.
Rob
How many do you need?
WOW!
How about two?
Do you take paypal?
Yes.
$1 each, pay shipping?  Msg me your address and I'll get a total cost.
I'll test the two I send by inserting them in a spare switch housing and removing them.  If they don't break they should be good for a couple installs/removals.
And a tip: when I replace these, I use male/female spade quick disconnects, or male/female bullet type disconnects to make the connections, rather than a splice or butt connector.  That way if they ever break again, I don't have to cut the factory harness shorter every time I have to replace one.
