jeepin4on4 Posted February 10, 2023 Share Posted February 10, 2023 My old 91 is in need of a build. Link to comment Share on other sites More sharing options...
Limeyjeeper Posted February 10, 2023 Share Posted February 10, 2023 Looks a bit low to me for what you are looking to do. I don't think you will get much change from $50k it is all the small stuff that adds up really fast. Link to comment Share on other sites More sharing options...
jeepin4on4 Posted February 10, 2023 Author Share Posted February 10, 2023 yea, very true Link to comment Share on other sites More sharing options...
Big_Mark Posted February 10, 2023 Share Posted February 10, 2023 if you are putting 37s on there, go straight to Dana 60s, otherwise all that effort to convert to Dana 44s will be wasted $$ Please post pics Link to comment Share on other sites More sharing options...
Limeyjeeper Posted February 11, 2023 Share Posted February 11, 2023 I agree if you are really going to run 500hp then you will probably need Dana 60 full float axles. The 44 is a strong axle especially with RCV axles and could work if you truss it and beef up the knuckles with gussets. The 60 is a much heavier axle weighing in at 565lb for the pair compared to around 300lb for D44's. It will handle 500hp with ease. Really depends on how you plan to use the finished MJ. On another note, an AX15 will never handle 500hp. 320hp with the HD upgrades is about as high as it will go. Not sure about the NP231. I am guessing you will be maxxing that out too. I would consider an Atlas II transfer case. Link to comment Share on other sites More sharing options...
jeepin4on4 Posted February 17, 2023 Author Share Posted February 17, 2023 Thanks, I will look into D60s Link to comment Share on other sites More sharing options...
Pete M Posted February 21, 2023 Share Posted February 21, 2023 superduty axles are very popular these days. they are becoming semi-plentiful in the junkyards. just make sure you don't accidentally buy the dana 50 front axle, which was used in some superdutys. they all have a metric 8bolt wheel pattern, so I would grab the 10.5 rear axle to go with it. (I think it was the 10.25 that was the smaller axle used on some). my buddy had an '03 with the 60/10.5 combo and it tore me up a little that he junked it after the accident rather than build something with it. https://torqueking.com/category/2005-2016-ford-dana-super-60-front-axle-id/#:~:text=Ford uses Dana Super 60,F550 Super Duty 4x4 trucks. Link to comment Share on other sites More sharing options...
jeepin4on4 Posted February 21, 2023 Author Share Posted February 21, 2023 Thanks Pete. Link to comment Share on other sites More sharing options...
jeepin4on4 Posted August 13, 2023 Author Share Posted August 13, 2023 The 91 was changed up a bit, going to leave it mostly stock. Pouring the $$ into the Comanche Camper project. The Eliminator is getting some new front brakes, bearings and seals for the D30. New front bumper and fitting the fenders, adjusting the 97 XJ doors, installing some rollers so I can prep it for paint. New Carpet next week and new Corbeau seats have been ordered. I will post more pictures as work progresses. Link to comment Share on other sites More sharing options...
jeepin4on4 Posted September 25, 2023 Author Share Posted September 25, 2023 Some tailgate work. Link to comment Share on other sites More sharing options...
jeepin4on4 Posted September 25, 2023 Author Share Posted September 25, 2023 I whipped up an "old school" bumper just to see how one would look. It needs a few things but after its coated with bed-liner paint it should look ok. Link to comment Share on other sites More sharing options...
jeepin4on4 Posted September 26, 2023 Author Share Posted September 26, 2023 Grabbed a set of Milestar Patagoina 35x12.5x15 very hard to fine but I found 5. Put them on to see how she will look. Still working on suspension and steering so another month before I can take it out in the dirt. Link to comment Share on other sites More sharing options...
Pete M Posted September 28, 2023 Share Posted September 28, 2023 On 9/24/2023 at 9:25 PM, jeepin4on4 said: Some tailgate work. perfection Link to comment Share on other sites More sharing options...
jeepin4on4 Posted October 1, 2023 Author Share Posted October 1, 2023 On 9/27/2023 at 6:47 PM, Pete M said: perfection Thanks Pete. Link to comment Share on other sites More sharing options...
Drahcir495 Posted October 3, 2023 Share Posted October 3, 2023 On 9/25/2023 at 10:12 PM, jeepin4on4 said: Grabbed a set of Milestar Patagoina 35x12.5x15 very hard to fine but I found 5. Put them on to see how she will look. Still working on suspension and steering so another month before I can take it out in the dirt. That looks tough. nice work on the tailgate too Link to comment Share on other sites More sharing options...
jeepin4on4 Posted February 1, 2024 Author Share Posted February 1, 2024 The Dana 44s I salvaged from Pick n Pull. Almost ready to install them. I will post some more pictures when they are installed. Link to comment Share on other sites More sharing options...
jeepin4on4 Posted February 8, 2024 Author Share Posted February 8, 2024 D44s finally done and going in this week. Link to comment Share on other sites More sharing options...
jeepin4on4 Posted February 19, 2024 Author Share Posted February 19, 2024 The rear D44 is installed. Link to comment Share on other sites More sharing options...
jeepin4on4 Posted February 25, 2024 Author Share Posted February 25, 2024 Front D44 is done, just waiting on my rotors and calipers. Rear brake lines are now in. Almost ready to drive it out and back her in for the front swap. Link to comment Share on other sites More sharing options...
