90comancheman Posted January 29, 2023 Share Posted January 29, 2023 So I did the 95/96 XJ booster upgrade to my 89 MJ except that I didn't do any of the modifications to the booster rod. Instead I put in an inline pressure switch in the brake line which turns on the brake lights when I push on the pedal and the switch detects a change in pressure. The switch and brake lights work great. The problem is that because I by passed the electrical switch on the pedal my cruise control quit working. Does anyone know how I need to wire it so that it will function? Any help will be appreciated. Link to comment Share on other sites More sharing options...
scguy Posted January 29, 2023 Share Posted January 29, 2023 28 minutes ago, 90comancheman said: So I did the 95/96 XJ booster upgrade to my 89 MJ except that I didn't do any of the modifications to the booster rod. Instead I put in an inline pressure switch in the brake line which turns on the brake lights when I push on the pedal and the switch detects a change in pressure. The switch and brake lights work great. The problem is that because I by passed the electrical switch on the pedal my cruise control quit working. Does anyone know how I need to wire it so that it will function? Any help will be appreciated. So the original brake switch has two switches, a normally open switch that closes when the brakes are depressed for lights, and a normally closed that opens when depressed for cruise canceling. How comfortable are you with wiring? The easiest solution I can think of uses a relay that's triggered by your existing pressure switch Link to comment Share on other sites More sharing options...
Ωhm Posted January 29, 2023 Share Posted January 29, 2023 Is the factory Brake Switch still connected up to the wires? If not, try that. Link to comment Share on other sites More sharing options...
90comancheman Posted January 29, 2023 Author Share Posted January 29, 2023 Yes, the CC wires are still connected to the old brake switch. Link to comment Share on other sites More sharing options...
90comancheman Posted January 29, 2023 Author Share Posted January 29, 2023 To answer SCGUY's question. I'm alright with wiring as long as I know where the wires need to go. Link to comment Share on other sites More sharing options...
Ωhm Posted January 29, 2023 Share Posted January 29, 2023 27 minutes ago, 90comancheman said: Yes, the CC wires are still connected to the old brake switch. Which state is the Brake Switch in, Brake light ON or Brake light OFF? Link to comment Share on other sites More sharing options...
90comancheman Posted January 29, 2023 Author Share Posted January 29, 2023 When driving the brake light switch is in the off position Link to comment Share on other sites More sharing options...
Airborne Janitor Posted January 29, 2023 Share Posted January 29, 2023 You need to make a jumper from your "new" pressure switch to your brake light switch. The cruise control leads don't have any power unless it's connected to the brake switch with the old connector plugged in. If you jumper power from your "new" pressure/brake switch to the old prongs on the brake switch, it should work fine. Just make sure you have the correct polarity, if you don't your brake lights won't turn off. I had to do something similar when I was wiring up my CC kit. This was a temp fix. I'm not using the stock brake switch at all, rather a GM/TCC switch with the oem CC pressure valve switch. The brown connector on the bottom of the pic is from the CC, it's what is usually connected to the brake switch, along with another identical brown connector for power to the brake switch itself. Link to comment Share on other sites More sharing options...
pizzaman09 Posted January 30, 2023 Share Posted January 30, 2023 I utilized a set of spade connector spliters on the stock brake switch on my cruise control install. They aren't the tightest fitting connectors. Link to comment Share on other sites More sharing options...
