Interior wire harness swap
I'm swapping the interior from an 87 Chief(auto) into my 89 base(manual). For the interior wiring, I was planning on basically just gutting my truck, then just using all of the wiring from 87 starting at the fuse panel connector. Is there anything wrong or not plug and play about this?
Also, I thought I remembered reading somewhere that an 89 engine computer is more advanced or better than an 87, so should I want to, or maybe even need to incorporate my current engine computer?
Should not have a problem, I did the close to the same thing, used an auto harness in a manual, just make sure to not use the trans harness(separate from main harness) from the auto if keeping manual
Alright thank you, the biggest thing I wanted to make sure of was that all of the interior harness(from where it connects thru the firewall with the fuse panel) was identical and plug and play from 87-89. I have been delayed a bit as I've been sick the last few days but should resume progress tomorrow hopefully.
