Heating Issue diagnosis
Hello all!
I'm trying to get to the root of my heating issue.
4.0L manual
89 Comanche Pioneer
So far I have done the following
-Flushed heater core
-Bleed cooling system
-verify my thermostat works
-verify my fan works
So my heater does technically work but it's quite pathetic in terms of how much heat I'm getting in the cab. Maybe just enough to defrost the windows when the temperature drops but not at all enough for a comfortable ride. My hoses are running hot and my thermostat is kicking on when it's supposed to so I'm at a loss.
Does anyone out there have any ideas as to what it could be!?
what temp thermostat do you have in the truck?
 If one of the heater hoses at the firewall, or both, are cooler than the heater hoses at the front of the engine there's an issue with the valve or the core. A fancy testing instrument like a bare hand will help verify this.
