At Augusta GA Pull-A-Part.
Grabbed the tailgate, the rear bumper could be fixed by someone. Originally blue, painted gold and served as a work truck. Less than 100k on the clock.
I dig the wheels but not the offset.
*C1
-SA CHARCOAL
161 Zone 61-Atlanta
1AA U.S. Dealer Retail
3VQ Customer Preferred Discount
ALA
ALK
APA MONOTONE PAINT
BAF 130 AMP ALTERNATOR
BCD 550 AMP MAINTENANCE FREE BATTERY
BGA POWER FRONT DISC/REAR DRUM BRAKES
CBA STRAIGHT BACK BENCH SEAT
CKJ BLACK VINYL FLOOR COVERING
CUM MINI FLOOR CONSOLE
DBB ALL MANUAL TRANSMISSIONS
DCK 4SPD MANUAL TRANS - AISIN
DMD 3.55 REAR AXLE RATIO
DRJ DANA 35 REAR AXLE
EPE Engine - 2.5L Power Tech I-4 Cyl.
GAC TINTED GLASS WINDOWS
GBB TINTED WINDSHIELD GLASS
GCB FRONT DOOR TINTED GLASS
GEH FIXED DOOR VENT GLASS
GRV LEFT MANUAL MIRROR
GUA OPEN
HAA AIR CONDITIONING
JAZ DO NOT USE - SEE JP, KA CLASSES
JCA 85 MPH PRIMARY SPEEDOMETER
JJA CIGAR LIGHTER
K3Z STRIPE/BADGE/MOLDING/COLOR
KDP STRIPE/BADGE/MOLDING COLOR
KWA STRIPE/BADGE/MOLDING/COLOR
LAP SHIFT INDICATOR WARNING LAMP
LBC GLOVE BOX LAMP
LMA HALOGEN HEADLAMPS
MB1 Black Front Bumper
MBJ Black Bumper
MFF Black Grille
MHB Bright Windshield Moldings
MMC
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
NMC Heavy Duty Engine Cooling
PB8 MIDNIGHT BLUE MET CC PRI PNT - HB8
QB8 SECONDARY PAINT
RA8 Delete Radio
SBA Power Steering
SCE Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
TZH Michelin Brand Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z57 Left Front Spring Group Vii
Z76 Right Front Spring Group VI
Build date 2/21/91
Body code TL61
Sold by PIERSON JEEP, GADSDEN AL
  • 4 weeks later...
After that much of the cab is removed is it it even possible to piece it back together? I know the back end of the frame can be chopped up but it sucks it can't be used whole
Pull-A-Part won't sell it whole so that does really matter in this case :(
But with welding all things are possible :D
