Anthi4078 Posted November 2, 2022 Share Posted November 2, 2022 Hey I’ve got a 87 Comanche and the interior lights won’t come on when you open the drivers door. The passenger door will turn them all on so I know they all work. The weird thing is that the drivers door will still activate the buzzer if you leave the key in or headlights on but it won’t turn on the lights. So I know the truck knows the doors open it’s just not turning the lights on. Any help would be appreciated, thanks. Link to comment Share on other sites More sharing options...
jdog Posted November 2, 2022 Share Posted November 2, 2022 The switch on the driver's side is a two wire switch, either one of the wires fell off or is rusted Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 2, 2022 Share Posted November 2, 2022 Pull the switch out of the door and clean it. Chances are it’s corroded and not turning on the lights. Link to comment Share on other sites More sharing options...
pizzaman09 Posted November 3, 2022 Share Posted November 3, 2022 Also check the wiring in the foot well, I had the wire for the lights pinched under a bolt holding the parking brake pedal assembly to the body. Link to comment Share on other sites More sharing options...
Manche1 Posted November 4, 2022 Share Posted November 4, 2022 I had the same problem, you need a new switch. Duralast SW90 is a direct replacement. I got mine at AutoZone and it was in stock. Link to comment Share on other sites More sharing options...
