No low beams
Lost low beams out of nowhere. Other morning I turned on headlights, and had no lows. Clicked to high and worked fine, then back and lows worked. Noticed the relay for lows was wet inside and changed it. Now I can't get them back again. Highs worked perfectly fine.  I have power to the dimmer switch. Swapped with a brand new one and same thing. I have no low beam voltage out of the headlight sockets. I'm a little stumped.
11 minutes ago, Pete M said:
do you have power at the relay?
No I don't. It's got an aftermarket harness but nothing up to the harness. It gets lost after the dimmer switch
1 minute ago, Ωhm said:
Photo @Monte721
Check C102 connector for front lighting issues.
Hmm I just recently had that one apart and cleaned. Maybe it got slightly unplugged or I didn't do a good enough job.
8 minutes ago, Pete M said:
is the dimmer switch clicking each time? (the actual switch not the handle)  I've had mine come loose from the column and not properly engaging.
Yeah it's definitely clicking. I took the new one and clicked it by hand so it's definitely switching over. It goes in and out of highs no problem.
Been raining for 5 days straight. Finally got to take a look. I have power up to the harness relay. Haven't tracked down a broken wire but I wasn't able to get to all of it yet. It's kind of a cheaper harness so I'm just gonna make my own with new relays and wiring.
