OE rear shackle
I recently acquired a 1990 short bed. It has a slight rake to the suspension - rear higher. The current leaf spring shackles
are 4 1/2 inches - bolt to bolt. Is this the OE length ? The springs appear to be OE.
Thanks
2 hours ago, pizzaman09 said:
Mine is all original and I have a slight rake with the rear higher, the bed always collects water in the rain.
There are 3 drain holes in the front of the bed. Check and see if they are open and allowing water to drain
Thanks I have an aftermarket bedliner that holds the water.  I hope to remove it and get the bed spray in lined prior to winter.
the drain holes are tiny.  make sure the spray-in doesn't seal them up. :L:
Thanks for the replies. My shackles are the same as in Fiatslug87's photo. So much weird stuff has been done by POs and I am trying to return the truck
back to normal as much as possible.
Thanks again
