No spark on New harness.
Need some help. Just put in my second engine harness. Now I have fuel and everything works but I don't have spark again. New cap and plugs tested two different coils and icms. New cps and tried to unplug it for a while and then try again and still different. What could be my issue?
  • Replies 51
Posted Images
1 hour ago, Pete M said:
have you confirmed that your distributor is spinning around?  I've seen a couple of stripped gears and broken shafts over the years.
do you have power going to the ICM?
I had taken it out and the hears were fine in it.
So I found a problem but not the problem I guess. That yellow wire was not connected properly so I fixed it snd still nothing. I also don't have power to my rem on the diagnostic ports if that helps with anything
