CarlG Posted July 18, 2022 Posted July 18, 2022 Hello everyone, I’m new to the group and well not super mechanical savvy, so bear with me. 87 2.5L 2WD It appears that the front passenger base of the coil spring has collapsed and blew through the bottom. Any way to repair this? It appears to be a molded part of the front axle assembly. I discovered it when changing the shocks. Any thoughts and wisdom is appreciated. Thanks, Carl
Pete M Posted July 18, 2022 Posted July 18, 2022 wow. at that point I'd be inclined to hunt down a whole new axle, but I'm not sure how available they are anymore. I'd wager that some company makes aftermarket ones.
Pete M Posted July 18, 2022 Posted July 18, 2022 or it's just a simple Dorman part now. https://www.amazon.com/Dorman-926-072-Driver-Spring-Bracket/dp/B082P8CX29/ref=asc_df_B082P8CX29/?tag=hyprod-20&linkCode=df0&hvadid=424751278055&hvpos=&hvnetw=g&hvrand=4123504844324291449&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9011095&hvtargid=pla-896674893013&psc=1&tag=&ref=&adgrpid=98636539323&hvpone=&hvptwo=&hvadid=424751278055&hvpos=&hvnetw=g&hvrand=4123504844324291449&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9011095&hvtargid=pla-896674893013
ratrapp Posted July 19, 2022 Posted July 19, 2022 damn didnt know they started making that now.i can save my gfs 95 zj front axle now.
CarlG Posted July 19, 2022 Author Posted July 19, 2022 I also was pointed to these as a more robust option. https://barnes4wd.com/products/jeep-tj-lj-mj-xj-and-zj-front-axle-coil-spring-brackets?fbclid=IwAR2vZP18O-9Q3WaZMwi0teYgs1z0jdK56rZcRourOgpt6ZTRNxGvnERf6wY&fs=e&s=cl
mjeff87 Posted July 20, 2022 Posted July 20, 2022 What is your location OP? I've got a 2WD beam axle out of my old MJ sitting in a barn in southwest PA. You can have it, you just have to go pick it up.
fiatslug87 Posted July 20, 2022 Posted July 20, 2022 There are two 2WD MJs in Northern California Pick-and-Pulls (Stockton and Windsor) if you’re in that area.
JYau Posted July 20, 2022 Posted July 20, 2022 I just pulled my beam axle out of my MJ since I'm doing a 4WD conversion. It's available, I'm located in MA.
zomeizter Posted July 20, 2022 Posted July 20, 2022 On 7/18/2022 at 8:35 PM, CarlG said: I also was pointed to these as a more robust option. https://barnes4wd.com/products/jeep-tj-lj-mj-xj-and-zj-front-axle-coil-spring-brackets?fbclid=IwAR2vZP18O-9Q3WaZMwi0teYgs1z0jdK56rZcRourOgpt6ZTRNxGvnERf6wY&fs=e&s=cl Barnes is legit, fan here...
