fiatslug87 Posted July 13, 2022 Posted July 13, 2022 I came across the attached control arm length list, why would lifting 2-3” require shorter upper control arms? Just trying to make sense of things.
ghetdjc320 Posted July 13, 2022 Posted July 13, 2022 Assuming you have adjustable uppers and lowers, just use the lowers and center the axle. Then use the uppers to set the caster angle.
75sv1 Posted July 13, 2022 Posted July 13, 2022 Another list I have has : With stock Control Arm Mounts With RE Drop Brackets Rough Country Brackets Lift Height LCA UCA LCA UCA LCA UCA Stock 15.75" 15" N/A N/A 2" 16" 15" N/A N/A 3" 16" 15" N/A N/A 4" 16.33" 15" 15.75 15" N/A 4.5" 16.5" 15" 15.875" 15" 15.75" 15" 5" 16.6" 15.25" 15.25" N/A 6" 17" 15.5" 16" 15.5" 15.875" 15.125" 7" 17.36" 15.75" 16" 15.75" N/A 8" 17.75" 16" 16.33" 16" 16.25" 15.524" 9" 18.25" 16.25" 16.6" 16.25" N/A 10" 18.75" 17" 17" 17" N/A I'd take it as get it in the ball park.
fiatslug87 Posted July 13, 2022 Author Posted July 13, 2022 Thanks for the replies. I just looked at my other truck, at stock height the upper control arm is higher at the axle than the frame. As the axle is initially dropped straight down (to keep it centered) the arm length decreases then increases as it’s lowered more. I thought it was level to start with.
Andy in Pa Posted July 13, 2022 Posted July 13, 2022 6 hours ago, 75sv1 said: Another list I have has : With stock Control Arm Mounts With RE Drop Brackets Rough Country Brackets Lift Height LCA UCA LCA UCA LCA UCA Stock 15.75" 15" N/A N/A 2" 16" 15" N/A N/A 3" 16" 15" N/A N/A 4" 16.33" 15" 15.75 15" N/A 4.5" 16.5" 15" 15.875" 15" 15.75" 15" 5" 16.6" 15.25" 15.25" N/A 6" 17" 15.5" 16" 15.5" 15.875" 15.125" 7" 17.36" 15.75" 16" 15.75" N/A 8" 17.75" 16" 16.33" 16" 16.25" 15.524" 9" 18.25" 16.25" 16.6" 16.25" N/A 10" 18.75" 17" 17" 17" N/A I'd take it as get it in the ball park. Yes, this is much more achievable and makes more sense. Keep in mind that first chart is changing the length of the uppers by less than 3/16's" from stock to 4". This can't be more than a 1* difference in castor, probably less. It becomes more critical when the lowers are extended past the recommended dimensions (to push the axle forward slightly). But as long as everything moves forward the same amount it works fine.
