Whitaker717 Posted July 8, 2022 Share Posted July 8, 2022 Hi guys, as the title states, is it possible to tighten the tow mirror arm? The pieces that bolt yo the bracket inside the door. I have a couple I would like to put on my Comanche but bracket is a bit loose. Therefore the arm will move a bit when bolted to the door. If anyone has any idea how to tighten it or what to do I would appreciate it. Link to comment Share on other sites More sharing options...
Whitaker717 Posted July 9, 2022 Author Share Posted July 9, 2022 Can someone who has these mirrors tell me if the arm brackets move? On both mirrors I have, the bottom bracket moves but on one of them the top bracket moves too. Trying to figure out if it is able to be tightened up. Link to comment Share on other sites More sharing options...
Pete M Posted July 9, 2022 Share Posted July 9, 2022 what do the attachment points look like? I don't have a pair to check. Link to comment Share on other sites More sharing options...
Whitaker717 Posted July 10, 2022 Author Share Posted July 10, 2022 Here you go Pete. The top and bottom points move on one of them. I don’t see how you tighten or adjust them. IMG_4792.MOV Link to comment Share on other sites More sharing options...
Pete M Posted July 10, 2022 Share Posted July 10, 2022 well, that's puzzling. there isn't some sort of tiny set screw hole for the top pivot, is there? Link to comment Share on other sites More sharing options...
Whitaker717 Posted July 10, 2022 Author Share Posted July 10, 2022 I’m not sure. If there is I can’t see one. Someone else asked the same thing. I would think you could tighten that somehow. Idk though Link to comment Share on other sites More sharing options...
Pete M Posted July 10, 2022 Share Posted July 10, 2022 @eaglescout526 anything in the computers that sheds light on this conundrum? Link to comment Share on other sites More sharing options...
Pete M Posted July 10, 2022 Share Posted July 10, 2022 so I broke out the big red paperback (89 shop manual) and there isn't any word on the issue. I'm guessing that the friction coefficient is set when new and that's it, they either get loose with time or freeze up with time. Link to comment Share on other sites More sharing options...
Whitaker717 Posted July 10, 2022 Author Share Posted July 10, 2022 I was kind of thinking the same thing. I might try to disassemble one to see what is going on with it. Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 10, 2022 Share Posted July 10, 2022 3 hours ago, Pete M said: @eaglescout526 anything in the computers that sheds light on this conundrum? I’ll have to check the service library and see. And I’ll check my service bulletin books too. Didn’t think to try any of those. Whitaker and I spoke behind the scenes about this and I told him to see if anyone out there as run into this issue. Seems like not a lot of us have. But then again, how many MJs are on here with tow mirrors? Link to comment Share on other sites More sharing options...
Pete M Posted July 10, 2022 Share Posted July 10, 2022 the usual problem I've seen is that they have frozen in place. Link to comment Share on other sites More sharing options...
Whitaker717 Posted July 15, 2022 Author Share Posted July 15, 2022 Anyone with this type of mirror, on the top part there are two indentations that look like a spanner wrench might go into it. I don’t know if mine are deep enough. Does anyone who has these mirrors have the same two indentations. I wonder if you could get a spanner on it and turn the round part. Thoughts? Link to comment Share on other sites More sharing options...
Pete M Posted July 15, 2022 Share Posted July 15, 2022 can you share a photo of what you're talking about? Link to comment Share on other sites More sharing options...
Whitaker717 Posted July 15, 2022 Author Share Posted July 15, 2022 There is another indentation on the other side Pete Link to comment Share on other sites More sharing options...
Pete M Posted July 16, 2022 Share Posted July 16, 2022 you may be on to something there... Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 16, 2022 Share Posted July 16, 2022 Interesting development. Link to comment Share on other sites More sharing options...
Whitaker717 Posted July 16, 2022 Author Share Posted July 16, 2022 I have an extra one so I will keep everyone posted. Link to comment Share on other sites More sharing options...
watchamakalit Posted July 16, 2022 Share Posted July 16, 2022 Link to comment Share on other sites More sharing options...
