I’m at a loss here, I recently acquired a 2.5L 86’ for cheap that hadn’t run in a while and was missing its transmission. I’m happy to say it runs and drives now, but like absolute garbage. It’ll sit and idle, smooth, all day long. But if you try and rev it (above ~1000rpm or so) it will sputter and begin to backfire through the intake. It won’t die though, although the popping does get noticeably more stronger. I indexed the distributor 2 teeth back and it allowed a little throttle to be applied, but it’ll backfire through the exhaust instead of the intake.
Here’s what I’ve checked so far:
- Distributor timing
- Compression ( #1 I didn’t check because it’s hidden behind the A/C compressor, #2 135psi, #3 140psi, #4 135psi)
-CPS voltage
-exhaust blockage (ran bad with exhaust not hooked up)
I haven’t tested fuel pressure but I think it would be ok. New fuel pump and fuel filter were just put in so maybe a blockage in the line? I also have very little vacuum at idle, there’s some for the brake booster but none anywhere else and none of the dash vents work. It also does have a “high altitude” CPS in it for some reason so would that maybe cause it? I have an extra CPS for a 4.0 that I can toss in if it’ll work or not.
  • Replies 67
1 hour ago, eaglescout526 said:
TPS adjusted?
MAP readings up to spec?
Vac lines secure and not damaged?
Coolant normal?
O2 working?
I’ve checked the MAP with another I know is good and it’s made no difference. Coolant was good and it had no extra pressure or exhaust smell. Vac lines have been checked and I do not hear any leaking like I would. I haven’t adjusted the tps but I did plug in a good one on a TB I have laying around and it didn’t have any difference.
3 hours ago, Dickinson County Comanche said:
They looked good although maybe just a skosh toward the lean side.
many a day, I've had this exact issue with an engine only to find out that under a load, the spark plugs, or ignition wires were leaking fire and it simply wouldn't rev.
The cap and rotor were kinda worn, I have new ones coming in tomorrow
Hopefully this is it. I threw a spark tester on it and it loses spark then misfires, it doesn’t do it however when it’s idling so hopefully it’s just the cap and rotor being worn out.
New cap and rotor have done nothing. I tested the good ICM and coil from my 89 4.0 and it did nothing. It has very hit-or-miss spark at anything above basically idle. I’ve put in 2 CPS’s and neither of them have improved it any. I’m genuinely at a loss here. Distributor is in time, good plug wires, and all of the plugs have been gapped (minus cylinder 1, but I can verify that it’s firing) to spec. Distributor doesn’t have a major amount of play, and is on the correct tooth of the cam.
Mind posting a pic of the engine bay? Maybe I can see if something is out place.
I also recommend a TPS adjustment just to rule it out as if it’s reading the position to dump more fuel in than what the engine can keep up with for the air ratio, it can throw things out of wack, and verify the fuel system is working properly like with pressure, no bad injector gaskets and fuel pump. I had the filter come off in the tank once and it made driving rough for me with loss of power. Has the fuel filter been replaced recently?
The whole fuel system has been gone through. I have verified already that it is not something to do with the fuel system as it doesn’t rev even with me bottle feeding it gas down the TB. It has to be spark-related somehow as it is hit-or-miss when it revs up.
51 minutes ago, eaglescout526 said:
All terminals and contacts related to the spark system has been cleaned and shiny right? Could also be having an intermittent injector issue.
I just cleaned the main block ground to no avail. All of the grounds check out ok as well and they seem to be getting proper voltage (~12.01V or so)
Take that air bonnet (aka ADAPTER, Air Intake) off at the throttle body and make sure you're not starving on air. Look/make sure the throttle plate is moving.
How do the connections on the starter relay look?
We can always do a run down of the sensors to make sure they are supposed to be at their proper values.
I’ve checked every connection I can and they all seem ok. Which sensors should I try first?
It’s something to do with ignition. It runs just as bad with the air intake on as it does when it’s off. I appreciate the help though.
Well we can check the injector and make sure it’s resistance is correct. Since it’s an 86 it’s gonna have a wide open throttle WOT switch, make sure that’s not stuck, EGR solenoid and TPS to start. You said the CPS is outputting correct voltage so we will leave it alone for now.
I actually just tried to probe the CPS for the correct voltage and I got nothing. Could it be that the flywheel got a little bit rusty due to sitting out exposed when there was no transmission on it?
