Swap to AMC V8 or to 3.4 Chev or Firebird?
Thanks for letting me join this awesome Forum!
 I recently purchased a 1986 Commanche 4x4. It has a original factor replacement 2.8 in it with about 20,000 on it. The trans is having issues on the truck.
  My question about the Jeep is do I replace the engine with a 3.4 from the wrecking yard and rebuild the trans or……….. I have a AMC 360 - 350 hp that was recently built that has a recently built 904 trans. I have no car that I need to put the 360 in. Do I use this combination in the truck after changing the trans tail shaft or use the 3.4 engine. What changes would I have to make to install the 360 or a 3.4?
the 3.4L block will go right in and make use of all the 2.8's accessories/intake/exhaust.  if the 2.8L is in good shape, you can leave it too and just focus on the trans.  :L:  there's a good thread on the 3.4 swap in the link in my signature.
the 360 will need a different all-the-things-everywhere.
The 360 is a physically large engine.  You can make it fit but it will take a lot of custom work.   And nobody makes any swap kits that will help.
I'd go with a 3.4 from a GM F body (Camaro/Firebird).  Grab the whole wiring harness with the engine and it's a straightforward swap.  If the donor has the 4L60 automatic, I'd keep that as well.  Easy to adapt it to the Jeep t-case (or just run it as 2wd if that's what you have).  That way you get a pretty good overdrive.
:yeahthat:
Or if you really want the V8 I'd suggest an ls swap.
2 hours ago, The86manche said:
It might be an endeavor but I'd say slap that 360 in.
When 2.8 dies I plan to put a an amc engine in mine. 304/360/ or the rare 401 if I can find one.
It's getting harder and harder to find parts for an AMC V8.  And the 401 doesn't take an overbore very well.  I'd focus on the 360 if I was going to swap in an AMC these days.
Though I'm much more likely to take out an AMC and replace it with a GM or Ford V8.  Those are a lot easier to find parts for.  That would be my plan if I go back to full size Jeeps.
That is slightly true. Blocks and parts are still a plenty around me here on the east coast. Maybe not a 401, those are harder to find. There was a guy with a stash of 401 blocks out in New York but he wanted around 5k for everything.. which is still a lot of money for just motors..
And if I could help it, I'd definitely try to avoid boring out any engine I put in it.
I just like the idea of putting an amc heart in an amc vehicle.
